HB-RE023 in Bora Ultra?
havana
by havana
Perphaps this is stupid question, but is it a problem to put HB-RE023 bearings (bearings+retainer) into a Campagnolo Bora Ultra (2015) wheel instead of the original HB-HY123 ceramic bearing?
Most "innovations" in cycling are solutions for non-existing problems.
havana
by havana
Anyone?
Ironbarista
by Ironbarista
I'm thinking no problem but you will loose all the benefits of the Cult bearing system. Most likely you'll have to use grease instead of oil. Why not just get the proper bearings?
bm0p700f
by bm0p700f
you can fit HB-RE023 but you have to use grease. I dont know if the lofe of the stainless cups and cones are affected, possibly not but I dont know. The ceramic balls should not wear. a clean a relube with light oil is probably all thats needed. the cones and cups will wear before the balls do.
havana
by havana
- Replaced ceramic bearings for steel ones > wheel is still running like bearings are worn out.
- Swapped body for a brand new one > still the same.
- Ordered original set of ceramic bearings 2 days ago. Let's see if that helps.
havana
by havana
Looks like the cones are damaged.
I need the HY-022, which I cannot find anywhere...
pdlpsher1
by pdlpsher1
A Campy authorized dealer can order any replacement parts for you.
How did you damage the cones? From a lack of lubrication?
bm0p700f
by bm0p700f
Yes talk to a pro shop. Hy 022 is normally available I know I can order them but I don't stock them outside of the service kits. You have a rear wheel I presume as the front in 2015 moved to a smaller cup cone and bearing due to the smaller are used.
TonyM
by TonyM
pdlpsher1 wrote:
Thu Jul 25, 2019 9:39 pm
I was told from Campy that the CULT bearings don't need any lubrification.
havana
by havana
I have a theory about the damaged cones, but I'm a bit ashamed to come clear :D
About two years ago I opened up the hubs for the first time to see how the bearings were doing and to see learn more about the construction of the hub. In the process, I lost 1-2 ceramic balls from the retainer ring. I just couldnt find them anymore, so I used two steel balls I had left from my spare parts container. They came of an old Fulcrum 3 wheel.
The original idea was just to do 1-2 rides with them, order new balls and replace them but for some reason I didn't care / forgot / whatever. I think that's what damaged the cones.
markyboy
by markyboy
TonyM wrote:
Fri Jul 26, 2019 1:31 am
Thats what i always thought cult bearings dont need lube
Colnago master with campagnolo super record 12
Pinarello f8 with dura ace di2
Eddy merckx 69 ultegra disc winter bike ultegra r8000
pdlpsher1
by pdlpsher1
All bearings need lubrication. The CULT doesn’t need grease but just a few drops of oil.
markyboy
by markyboy
pdlpsher1 wrote:
Fri Jul 26, 2019 7:48 am
:thumbup:
TonyM
by TonyM
That's what I told Campagnolo technical support again and again and they finally after so many emails said that if I really want to lubricate I could use some light oil but this step was really not necessary....
bm0p700f
by bm0p700f
:unbelievable:
