28mm tire on 23mm rim?
petosagan
by petosagan
hi,
my actual wheelset is Width: External: 25 mm, Internal: 17 mm and it is ok with 28mm tire but my old wheelset is : External: 23 mm, it is ok to put 28mm too?
thanks
Hexsense
by Hexsense
Yes,
28mm tire on 25mm rim suffers a bit on aerodynamic (already have 3mm or more overhang).
28mm tire on 23mm rim may suffer a bit more.
Both aren't 28mm tire on 28mm or wider rim anyway. Since you don't bother matching tire width to rim width to begin with, just screw aero and ride what you feel good.
LouisN
by LouisN
No problems. I have a "spring weather-comfy" setup with 28mm Rubino Pro's on 19 mm rims. Running 75-80 PSI on them. Yes, no as aero, but super smooth to ride, and handles surprisingly well.
Louis :)
petosagan
by petosagan
Great To here
Thanks
Envoyé de mon SM-A530W en utilisant Tapatalk
