Enve 2.2 with Extralite Hubs
exctasy
by exctasy
Hi there,
I'm currently looking at rebuilding my enve 2.2 tubulars to extralite hubs.
There seems to be diferent models of extralite cyber hubs.
For a 56-60kg rider, who enjoys climbing, which hub should I be choosing?
Thanks!
alcatraz
by alcatraz
Check the rim hole count. If you want to use the newest version that allows for high spoke tensions sp-x/sp-t then you can only use 20/24h rims.
(Sp-t is a triplet hub that wont work with alternating left/right drilled holes)
The most common hubs are sp/sp which support lower tensions and are available in 16/20h front and 20/24/28h 1:1 rear.
