Yes, that's what I was meaning to say. Thanks for the clarification.farsportssandy wrote: ↑Wed Dec 01, 2021 7:36 amIt's actually duty prepaid by our forwarder, not duty free.
FARSPORTS DISC CARBON WHEELSET Test & Review
Forum rules
I ordered a pair of the Ultralight Feder wheels (FSD35CM-27T-SUD) on Nov 25. Hookless rims with 35mm depth, 28mm outer width, 22mm inner width. FAR230 hubs with standard bearings and Shimano freehub. Sapim CX-Super spokes. Claimed weight is 1070 grams, and with a no-hole rim bed, will not require tape to set up tubeless with Continental 5000S TR tires. Will post weight and impressions when they arrive.
EVO1 | 5.37kg
EVO3 (sold) | 6.51kg
EVO4 | build thread coming soon
S5 Disc
SystemSix (sold) | 8.01kg
P5 Disc | heavy but fast
S5 Disc
For full aerodynamic effect you need a tire that is 105% the (actual) with of your tires, so if your 28mm tires actually measure 30mm mounted you'd want a 32mm wide wheel if possible.
Here is an excellent Marginal Gains vidio on the subject:
https://www.youtube.com/watch?v=mDZ61aMegnQ
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
I wouldn't ride a 28c tire on a hookless rim. The pressures needed would probably be at the higher acceptable limit for hookless rims.
- robbosmans
- Moderator
- Contact:
The deeper the better, but it depends on where you ride (do you have a lot of crosswind’s?), what weight you are looking for and so on
Ordered Farsports Gravel wheelset (hooked 30mm depth/30mm external width w/ DT350 hubs) on 11/11, shipped 11/16, and received 12/4 in the USA. Fantastic build quality. Advertised as 1370g but actually weighed in at 1340g.
Damn. I ordered the same exact wheelset on 11/11 and it hasn't even shipped yet...scoobydrew wrote: ↑Sun Dec 05, 2021 11:16 pmOrdered Farsports Gravel wheelset (hooked 30mm depth/30mm external width w/ DT350 hubs) on 11/11, shipped 11/16, and received 12/4 in the USA. Fantastic build quality. Advertised as 1370g but actually weighed in at 1340g.
Also bougth them on 11/11. I asked about shipping time and I was told they would ship this week. So let's be a bit more patientsheepbleat wrote: ↑Mon Dec 06, 2021 2:24 amDamn. I ordered the same exact wheelset on 11/11 and it hasn't even shipped yet...scoobydrew wrote: ↑Sun Dec 05, 2021 11:16 pmOrdered Farsports Gravel wheelset (hooked 30mm depth/30mm external width w/ DT350 hubs) on 11/11, shipped 11/16, and received 12/4 in the USA. Fantastic build quality. Advertised as 1370g but actually weighed in at 1340g.
