was it easy mounting the tire on the rim?skymasternl wrote: ↑Tue Mar 23, 2021 7:28 pmDSC_3526.jpg
Just received my Feder 45mm with DT240 hubs today and paired it with the new Pirelli P Zero Road
Measured weight was front 642g rear 735g, only 7g than the claimed 1370g so pretty good!
FARSPORTS DISC CARBON WHEELSET Test & Review
Forum rules
My set came in total 1013g, same depth and hubs.
Ordered with 20/24 CX ray spokes and alu nipples.
But that was more than a year ago, maybe rims are lighter these days.
yes, ordered same as you, I guess you drew the short stick 30g+/- he he; you satisified with them, any flex ?
Thanks
I made my order as well. Not paid yet, as they promised to send paypal request tomorrow.
---Rims: Farsports Feder series rim FSD45CM-28T-SUD , tubeless ready disc rim, 45mm depth, 28mm external width, 21mm internal width. with spoke holes in the rim bed, 24/24h, UD matte rim finish, no logo.
---Hubs: Carbon Ti straight pull, Central lock , 24/24h Through axle, axle size: 12*100/12*142mm , Shimano 11s free hub body, black.
---Spokes: Sapim cx-ray black.
---Nipples: Sapim sill alloy black.
---Weight: 1300g+_30g
They also promised to find a FARSPORT decal color, that would match my Scott Foil frame fluorescent yellow/green color https://pictures.ssg-service.com/269/26 ... oom_11.jpg
I spoke with Tom over email, and responses were great and fast.
I`m excited:)
I`m excited:)
Finally received my new wheelset today: Farsports Gravel FS30/30G, DT Swiss DT350 with 36T, 24/24 spokes. Measured weight 1391g, posted weight was 1370g, so that is very good. I ordered it with tax prepaid on February 15th, arrived approx. 5 weeks later, it was delivered by DPD.
Enid: Scott Addict RC Ultimate Team Ed - 7.2 kg (in. pedals and bottle cages)
Anyone here running the Kaze series 26mm external width with Vittoria tires? Just curious about the actual installed width. I am thinking about getting a set of Kaze 26mm wide 50mm deep rims and I would ideally want to run 25c vittoria corsa clinchers but I want to make sure that the tire isn't going to baloon out. Related to that, is anyone here using their classic series rims in 25mm external width and actual installed tire widths?
if it helps, I run at the back 25mm Conti GP5000 on Kaze 26 external; the tyre measures 26,7mmspacelahanaa wrote: ↑Thu Mar 25, 2021 9:38 pmAnyone here running the Kaze series 26mm external width with Vittoria tires? Just curious about the actual installed width. I am thinking about getting a set of Kaze 26mm wide 50mm deep rims and I would ideally want to run 25c vittoria corsa clinchers but I want to make sure that the tire isn't going to baloon out. Related to that, is anyone here using their classic series rims in 25mm external width and actual installed tire widths?
Oh yes...short stick...I was crying all night long.
Although these wheels are not ridden often, I'm happy with them.
No flex at all, but bear in mind I'm around 63/64kg.
But it is a pure pleasure riding them on Krvavec mountain.
My wheels have been delivered.
FSD45CM-28T-SUD - 45mm Deep, 28mm Wide Rims onto Farsports RD230 Hubs with CeramicSpeed bearings, using CX-Ray Spokes (21)
Ordered 25th Feb
Shipped 19th March
Arrived UK 26th March
Weight 1,233.7 Grams - Under weight tolerance of 1240-1270g, could have been c. 30g lighter with CX-Super spokes
Front: 572.5
Rear: 661.2
Pics:
Saved 304g over my current wheels (Hunt 50 Aero Disc), which is nice, waiting for other bits so won't be riding for about 3 weeks, will update with a ride report at that point.
Ordered 25th Feb
Shipped 19th March
Front: 572.5
Rear: 661.2
Pics:
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
topt, thanks for the info. I think I'm gonna go with their classic rims with a 23mm tire in front and 25mm tire in the back.topt wrote: ↑Fri Mar 26, 2021 1:03 amif it helps, I run at the back 25mm Conti GP5000 on Kaze 26 external; the tyre measures 26,7mmspacelahanaa wrote: ↑Thu Mar 25, 2021 9:38 pmAnyone here running the Kaze series 26mm external width with Vittoria tires? Just curious about the actual installed width. I am thinking about getting a set of Kaze 26mm wide 50mm deep rims and I would ideally want to run 25c vittoria corsa clinchers but I want to make sure that the tire isn't going to baloon out. Related to that, is anyone here using their classic series rims in 25mm external width and actual installed tire widths?
I run the same config, Gp 5000 23mm comes at 25,3mm on Kaze rimspacelahanaa wrote: ↑Fri Mar 26, 2021 3:09 pmtopt, thanks for the info. I think I'm gonna go with their classic rims with a 23mm tire in front and 25mm tire in the back.topt wrote: ↑Fri Mar 26, 2021 1:03 amif it helps, I run at the back 25mm Conti GP5000 on Kaze 26 external; the tyre measures 26,7mmspacelahanaa wrote: ↑Thu Mar 25, 2021 9:38 pmAnyone here running the Kaze series 26mm external width with Vittoria tires? Just curious about the actual installed width. I am thinking about getting a set of Kaze 26mm wide 50mm deep rims and I would ideally want to run 25c vittoria corsa clinchers but I want to make sure that the tire isn't going to baloon out. Related to that, is anyone here using their classic series rims in 25mm external width and actual installed tire widths?
