by Indyx on Sun May 31, 2020 11:56 pm
Quick first impression review for Feder 45 Disc Wheels.
Here is what I purchased:
-Feder 45 x 26mm disc wheels with Carbon Ti Center Lock Hubs, Tubeless, no spoke holes drilled.
-Claimed weigh 1280 +/- 30G
This is my second pair of Farsports wheels. I have a 1 year old pair of the "Classic" 38 MM deep wheels Rim Brake, with Carbon Ti Hubs. Great wheels overall, but I always thought the brake track was medicore with performance and residue remainder. However, that is to be expected with $800 dollars with $500 dollar hubs. With disc wheels, the concern matters less.
Anyhow, ordered in late April. Communication with them is always good. They even shipped my wheels via DHL per my request, as USPS is taking forever to deliver things with Covid.
Wheels arrived, well packaged. Couple extra spokes, and tubeless valve stems, which I didn't expect.
Weight on my scales 1310 so on the upper end of the claimed weight, but still one of the lighest 45mm disc wheelsets on the market.
Planned to use GP 5000 TLs. I opened them, and let them hang with 5 lb weights attached to them in the sunlight for ~8 hours, as I heard horror stories in mounting.
They went on the wheels fairly OK. Required the use of tire levers, but I had each one on in maybe 5 mins. I was expecting a horror show, but it was a 3/10. I've definetely had harder times mounting CX tires and GP 4000s on wheels. Not sure if was the sun/weights, or the wheels but fairly easy.
Went to inflate them with a track pump, and to my pleasant surprise they both pumped up fairly easily and popped into place. Let them sit overnight without sealant, and one tire held air overnight, and the other deflated, but today when I removed the valve cover it was loose.
Added 25ml of sealant today, pumped them back up, so we shall see how they do.
So far, first road tubeless experience with these far sport wheels, pretty straight foward.
