recomendations for a lightweight tubular wheelset (budget £1000)
dim
by dim
Hi guys .... I need some guidance again
I'm looking for a lightweight tubular wheelset that I will use for shorter quality fast rides with a bit of climbing. These wil be used on my Trek Emonda SL6
my budget will be £1000 and I will buy the main components (rims, hubs) over a 2month period, and have my LBS build them with the appropriate spokes on the 3rd month (I have to do it this way or else my wife spends my money on groceries (I struggle to save money) :(
I don't have a clue what to look for, as this will be my 1st tub wheelset ... I also need suggestions for decent fast tyres that won't puncture on every ride
I know that this most probably has been discussed many times on this forum, but I'd like some help as there are many new rims just released
Trek Emonda SL6
Miyata One Thousand
Imaking20
by Imaking20
FSE rims and Carbon-Ti hubs. My 35mm wheels are 1091g with a mix of Sapim Laser (I think) and Sapim Race on the NDS. This also came in within your price range when I had them built up by Fairwheel bikes. Fantastic wheels.
As for tires - choose your color of Veloflex.
Current:
Acid Mint Tarmac
Hakka MX
Retired:
Boone |Wilier Wonka|The Dentist|The Bucket List|Specialissima|Evo|T2|Blue|Project C6.0 | elt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge|Wilier Cento1 SL|Tarmac SL2
dim
by dim
Imaking20 wrote:
Sat Mar 23, 2019 12:07 am
thanks for that .... I will have a close look :thumbup:
Trek Emonda SL6
Miyata One Thousand
bm0p700f
by bm0p700f
I gave a tubular set built up with carbon Ti hubs. To give you an idea they are 50mm deep 23.8mm wide at there widest point and weigh 1170g.
If not the above wheels then carbon Ti hubs on rims that you like.
nachetetm
by nachetetm
Etienne
by Etienne
nachetetm wrote:
Sat Mar 23, 2019 9:49 am
Not the time to recommend open tubulars with carbon rims after the ENVE-Vittoria issue :-) At least until the dust settles and we have a better understanding if all the carbon clinchers are not safe with open tubulars or is just an ENVE thing. Veloflex has always specified than its tires shouldn't be used on carbon rims, I would take this seriously.
[/quote]
The OP is looking for tubular wheels ... so no problem with Veloflex tires on carbon rims :wink:
nachetetm
by nachetetm
I didn't realize the OP was asking for tubular wheelset. My fault!!
audioblazer
by audioblazer
Check out wheelsfar.com . Farsports wheelset 25x 23mm wide rim . 870g with extralite hubs. USD1258
