New farsport wheels ordered but need advice on tyres
skyboy
by skyboy
After looking at cheaper Chinese brand wheels for a while now I've heard enough good reports to confidently make a purchase.
I had been running mavic ksyrium pro sl exalith with 25mm tyres, which are comfortable but in no way aero with the tyre really ballooning out past the rim.
The 50mm deep dish farsport wheels I just ordered are 18mm inner width and 25mm outer.
So far from my research I think the same 25mm gp 4000s II tyre that I normally use will balloon out to 27mm and 23mm of the same brand will balloon to a little over 25mm
Does anyone have any advice or experience on what tyre I should use on my new wheels? I've had good experiences with the gp 4000s II but would consider a different brand if it was a better fit.
Sock3t
by Sock3t
You never stated your use case. Are you racing? Are you pedaling along at 12mph on a multi use path?
skyboy
by skyboy
Not racing this season but have in the past and probably will again in the future.
For now it will be 100km leisure rides at 30kph on rural public tarmac roads.
TimF
by TimF
Do you have enough clearance on your frame or is this just a question on recommended tire width?
alcatraz
by alcatraz
For conti maybe go with 23c in front that expands to 25mm. In the rear maybe 25c?
/a
AJS914
by AJS914
I have 25mm GP4000s on the same Farsport wheels. They are great. We have rough roads around here so I appreciate an extra 2mm of volume.
So what is your concern? Either 23mm or 25mm GP4000s would work just fine as long as they fit your frame. In the end you are talking about a 1mm difference on each side of the tire. It's not a huge difference.
If you are concerned about aero, the 105% rule and all that, the 23mm tires will have a slight (like 2-3 watts) aero adantage. It doesn't sound like that is a factor for your riding.
The other option is to get a GP5000. A 25mm 5000 will be a little narrower than the 4000 and 1mm less tall.
skyboy
by skyboy
No problem with clearance, my bike would probably work just fine with a 28mm tyre.
My only concern was to get the best tyre for the rim and since I need to buy new tyres anyway I figured I might as well get ones that conform to the correct airfoil shape of the rims. Of course comfort is a concern too.
That photo is very helpful though so I now know exactly how a 25mm will fit, thanks!
AJS914
by AJS914
Even though I know the tire is probably 27mm wide and the rim is 25mm, when I look at it in profile it looks to be the same width to the eye. Like I said, it's a few watts.
Get the GP5000. It's their latest tire. A 25mm GP5000 will be halfway between a 23mm and 25mm GP4000.
skyboy
by skyboy
So it would seem that gp4000 23mm with no overhang or gp5000 25mm with about 1mm overhang but probably more comfortable and my even run better over my local roads. I'd say even if I was racing it would make no real difference to speed it might make a tiny difference in a time trial.
Thanks again, it will be a few weeks before the wheels arrive, I'm sure I'll have decided by then!
alcatraz
by alcatraz
Only real width matters. Some people take comfort that it says 25 on the tire when maybe a 23 is wider. Odd.
To optimize you need rims that fit the tire width you need. If you need to go over the width of the rims you kind of bought the wrong rims.
Same goes with too wide rims. A 60kg rider on 32mm rims is also inefficient.
But as always, whatever makes you want to ride your bike is a primary goal, efficiency is secondary. We can still aim for both though. :)
skyboy
by skyboy
Well that makes sense if a tyre is labelled 23mm and inflates to 25mm width then it's really a 25.
But why would a tyre brand like continental make two tyres gp4000 and gp5000 but have one wider than the other with the same same size written on the side of the tyre?
alcatraz
by alcatraz
They just use different rims as their standard to define the width. Conti must be using a very narrow rim and vittoria a wider rim.
They are going with the times though and start to use more commonly available rims so that newer tires don't measure as wide as previous ones.
... or closer to the specified width, to be more accurate.
skyboy
by skyboy
That makes sense wheels sizes have changed a lot in the last few years. However people have not got that much faster, I'm probably over thinking it especially since I don't compete.
clarinet5001
by clarinet5001
skyboy wrote:
Wed Mar 20, 2019 4:57 pm
Well, you're looking at the '105% rule' here, right? That states you'd need a tire <23.8mm actual mounted width to get the best out of these wheels...which would include no modern tires with labeled width >21-22c...
A tire up to 24.5-25mm actual width will still work ok, but if you go above that you lose nearly all of the aero bonus you'd get over shallow rims. So 23c up front is probably max and not a 23c GP4000Sii since it likely runs >25mm on 18c internal width.
dim
by dim
Specialized Turbo Cotton in 24's
Trek Emonda SL6
Miyata One Thousand
