No holes vs nipple holes?
deepakvrao
by deepakvrao
I read that you can order LB wheels with the option of no holes on the inner surface, so there is no need for rim tape.
In m y current alloy wheels, I use tape and if/when I have to replace a tyre, I often have to replace the tape too.
So, what are the pro/cons of having a rim without holes?
mattr
by mattr
They are a bugger to build. Have to thread every nipple in through the valve hole.
Can be done with cotton thread and a vacuum cleaner though.
Can't use concealed nipples (not really an issue anyway).
Rim doesn't need tape (obvuously) and theoretically a stronger rim.
Personally, i'd not bother, as i don't very often damage tape.
spud
by spud
pros - no tape to monkey around with, tubeless set up (depending on the rim) is very easy and robust
Con - breaking a spoke is more of an issue to deal with, especially if it breaks at the nipple, on a deep section rim. On the other hand, I haven't broken any spokes on newer wheels built with brass nipples. If getting wheels built without holes in the tire bed, using alloy nipples is an invitation to problems down the road.
bm0p700f
by bm0p700f
How exactly do you damage rim tape? Rims without spoke holes are not worth it. A thread steel insert and a magnet can get the nipples through but since Tubeless setups with tape are hassle free so I really don't get why you would the hassle of building a wheel with no spoke holes. Freight for no gain.
deepakvrao
by deepakvrao
When I remove a tyre, the tape gets scrunched up, and also the tape gets sticky, so re seating a tyre becomes difficult. I often add another layer of tape then to get it smooth again.
bm0p700f
by bm0p700f
How come I avoid the above problems? Use tape that goes to the edge of the rim, that how you avoid the tape scrunching up. If the tape is a bit too narrow it will scrunch when the tyre is removed.
Use dilute soapy water to reduce friction.
I have said it begore, tubeless woes are user error yet people instead of upping the skills assume they are doing nothing wrong and reach for a more complicated solution.
deepakvrao
by deepakvrao
bm0p700f wrote:How come I avoid the above problems? Use tape that goes to the edge of the rim, that how you avoid the tape scrunching up. If the tape is a bit too narrow it will scrunch when the tyre is removed.
So, what width would you recommend for a rim like the lb56 which is a 30mm outer and a 23 mm inner?
Sent from my SM-N950F using Tapatalk
spud
by spud
bm0p700f wrote:
Mon Mar 11, 2019 7:17 pm
As a wheel builder, your perspective makes complete sense. As a wheel buyer, my perspective has made sense, so far. As long as they don't break spokes, it's a cleaner installation with fewer parts.
MikeD
by MikeD
My Mavic and Shimano wheels have no spoke holes and the nipples thread into the rim (I think, since I've never had to replace a nipple). Never seen or even heard of the no spoke hole type where the rim has internal nipples. Who makes these?
mattr
by mattr
Most of the cf rim manufacturers.
They've been kicking around near enough 20 years now.
Lelandjt
by Lelandjt
I've done this. How much of a downside it is depends how good you are at sending nipples in. I actually prefer the process to how a nipple replacement is usually done on a tubeless rim. During the initial build it's of course more work than normal.
bm0p700f
by bm0p700f
Mavic and Shimano wheels do break spokes sometimes then no spoke holes is a pain. There is no up side to it. Again how come I get clean installs. I never have tape faff unless the rim is not sized right and if that was a no holes rim tape faff would ensue anyway.
Tape width should be 2-5mm wider than the internal width depending on how deep the central channel is.
MikeD
by MikeD
bm0p700f wrote:Mavic and Shimano wheels do break spokes sometimes then no spoke holes is a pain. There is no up side to it. Again how come I get clean installs. I never have tape faff unless the rim is not sized right and if that was a no holes rim tape faff would ensue anyway.
Is it better to have the tape go up the rim wall, or stop at the edge of the rim bed?
