Extralite Road Disc
mashiehood
by mashiehood
Damn it you will get your before I will - ouch on tarrif, we are lucky to be part of the EU in the UK so no tarrifs..... oh wait we are leaving the EU :cry:
youjettisonme
by youjettisonme
mashiehood wrote:
Wed Feb 27, 2019 8:46 am
Yep, they arrived! Haven't done anything with them yet, but they look great.
youjettisonme
by youjettisonme
Mounted some different (new) tired on these rims. The non-TRL Pirellis were way too lose. Not even passable. The Conti 5000 28 TLR are VERY tight. Tough to mount them with a lever even minus rim tape. Somewhere, I'll find the perfect temperature for the 3 bears poridge.
emotive
by emotive
youjettisonme wrote:
Thu Feb 21, 2019 8:38 pm
Thought of another question... I've been focused on tubeless tires, but which traditional clincher tires might work well with these hoops? Who has experience with using tubed tires with hookless rims?
I have ridden 8000km on the hookless version of Light Bicycle RR36C02 wheels. I run them with tubes. Started on a used set of Conti GP4000 II 28mm, then Compass 28mm, and now S-Works Turbo 28mm. I run 55/60psi. Tight to mount, it's important to get the tyre in the centre channel to be able to get the bead over the rim. I've only punctured twice. I bought a TyreKey and that helps with getting tight tyres on.
Klaster_1
by Klaster_1
mashiehood wrote:
Wed Feb 20, 2019 8:02 pm
I will mount some Pro One's in 25mm tubeless and run them for Spring and see what the testing will bring.
It'll be fine, tubeless tires generally sit tighter than tubed. I run 25mm One Tubeless and Pro One for several years on my hookless LB rims without any issues.
youjettisonme
by youjettisonme
emotive wrote:
Thu Feb 28, 2019 6:19 am
Thanks for the feedback. If I end up running them with tubes, I'll likely ride with my TyreKey as well. I have Tubolitos since it's actually less weight to ride with tubes in that case.
mashiehood
by mashiehood
just fitted my gp4000 on the wheels, my god they are a tight fit! no chance without levers. Look good otherwise, the profile on a 25mm tyre measures 27. Am riding 100k on them tomorow so will report back.
by Nefarious86
Pics and weights people....
Using Tapatalk
youjettisonme
by youjettisonme
mashiehood wrote:
Thu Feb 28, 2019 9:10 pm
You'll get those test miles in a lot sooner than me! I mounted some Trickstuff rotors, Ti rotor bolts. However, I have to wait for my Silca tubeless tape to arrive.
youjettisonme
by youjettisonme
Any comment on these Conti 5000s, non-tubeless?
by Nefarious86
Morkai wrote:I'm also looking to the new Extralites for my new wheels (or Bike Ahead biturboRoad), but I'll wait with the decision until reviews for the new Rotor One groupset are out (if any...)
Currently I have around 6k km on hookless Hunt 50 Carbon Aero Disc running tubeless Schwalbe Pro One 25mm and I dread the next time I'll have to replace the tyres.
Not because it's hard to fit new tyres, but because it's increadibly hard (and messy) to remove the old ones (last time I had to ask for help someone with arms 2x bigger than mine :))
I'm 62 kg and usually running 72 PSI front and 79 PSI rear. After fitting new tyres I pump them to ~90 PSI and leave them overnight (without any sealant). If they are still rock hard the next day, I deflate them, pour some sealant and pump back to my desired pressure.
I've had one tiny hole in the front that did not seal properly (not enough sealant left I think) 20 km from home and managed to ride back safely (later checked and the pressure went down to 29 PSI).
But they supposedly have a 'special tech' for securely fitting tubeless ready tyres and are recommending Schwalbe Pro One.
Pressure seems kind of high for your weight? I'm 84kg and run the same or less with tubes on 25mm tyres?
Using Tapatalk
saibot
by saibot
My set arrived this evening, (xd freehub body) came in 8g underweight
R: 576g F:496g
mashiehood
by mashiehood
well, im still alive! wheels are lovely, feel feathery light compared to the boat anchors i have (Enve 3.4 with formula hub weighed almost 1600g), in reality they are wheels which felt good! They look great on my Cervelo R5 and gets the bike to 6.1kg which for a disc bike to great.
spdntrxi
by spdntrxi
Fri Mar 01, 2019 1:37 am
looks good as long as the extralites are hooked.. which they are not :beerchug: be careful
youjettisonme
by youjettisonme
spdntrxi wrote:
Fri Mar 01, 2019 6:17 pm
Exactly. Seeme like most tubeless tires are going out of their way to advise not mounting on hookless rims.
