co2 inflator tubeless
pjctyk
by pjctyk
Can anyone recommend a co2 inflator for seating a tubeless tyre in an emergency when out on the road? (Just in case the tyre unseats itself from the 'shelf' on the rim?) One that will give a quick blast of air for a 25mm tyre.
Orlok
by Orlok
pjctyk wrote:
Tue Feb 12, 2019 11:36 pm
My opinion is that if you normally can pump it up with a floorpump you're also able to pump it up with a CO2 inflator. But give it a try or you'll never know. :wink:
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 6800 - Carbonspeed C38 - Tubeless
kode54
by kode54
The best kind for the quick blast is those with a trigger. For that purpose, I use the Genuine Innovations with trigger...something like this (mine is older)....
https://www.amazon.com/Genuine-Innovati ... way&sr=8-7
Normally, I use a twist knob type like the PDW Shiny Object one.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
pjctyk
by pjctyk
kode54 wrote:
Thu Feb 14, 2019 2:37 pm
Thanks for that info!
wheelsONfire
by wheelsONfire
Great question, actually for being sure of tire seating, i would bring an inner tube. Many tires need a compressor.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
