Rim ERD: 541mm
The following images will contain the rest of the necessary dimensions <--- Hopefully
1st image: Flange Distance Left, Flange Distance Right on both front and rear hubs
2ed image: Pitch Circle Left & Right on the front hub
3rd image: Pitch Circle Left on the rear hub
4th image: Pitch Circle Right on the rear hub
5th image: Distance Between Spoke Holes Right on the rear hub
6th image: Offset Spoke Hole Right on the rear hub
Thank You
joejack951 wrote: ↑Sat Dec 22, 2018 9:21 pm
If a CAD model is needed to assess the spoke length, shoot me the dimensions of everything (rim and hub, all relevant dimensions) and I can draw it up fairly quickly. I have some models set up for the task having built some oddball wheels myself (like a ISO 254mm rim with 16 holes laced to a 32 hole hub, converting my son's CNOC 14 to a BMX freewheel hub from a coaster brake hub).
