Thoughts about new Enve Carbon Road hubs?
scb
by scb
ergott wrote:
Sat Dec 08, 2018 2:12 pm
kavitator wrote:
Sat Dec 08, 2018 11:16 am
I think ENVE is not targeting them to sale them a lot.
"Hey if their hubs are worth $1000 their wheels must be better than..."
That's what they are shooting for.
But Enve only charges $100 more than DT Swiss 240.
LeDuke
by LeDuke
Huh? Checking the first retail site that came to mind, Fairwheel Bikes, the DT Swiss 240 hub set was $634, in the most expensive configuration (Boost, CL). $580 for road/rim.
kode54
by kode54
i running on the Enve gen 1 carbon hubs...and had some issues on one pair which developed some side to side play in the rear hubs. Enve replaced the hubs and relaced the wheel to the original rims under warranty.
i have not had any issues thereafter. i liked that I could service the hubs like the DT Swiss. quick n' easy.
now, OTOH, with Mavic internals...i gradually got rid of a few wheel sets due to the issues i had with the hubs. one with side to side play in the cassette that went away with replacement which i think was the Delrin or Teflon white sleeve inside the freehub. i didn't care much for the servicing of their hubs.
spdntrxi wrote:
Fri Dec 07, 2018 2:07 am
I used Enve's older carbon hubs .. extralite hyper's... love them both. Extralite might not be great in the winter or foul weather and need routine maintenance which I did myself but I didn't have a problem with enve carbon hubs either. I'm no lightweight @ 80+kg and more of a sprinter.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
scb
by scb
LeDuke wrote:
Sun Dec 09, 2018 4:22 pm
On their website, for example, 3.4 rim clinchers with DT Swiss are $2900 and with new enve hubs $3000. Guess they are absorbing some of the cost diff between DT and Enve hubs
bm0p700f
by bm0p700f
For £950 you can get Royce hubs with titanium flanges and carbon shell and titanium axles e.t.c
Not light but a work of art. I have bought a set of these made, with flange spacings I find acceptable.
bm0p700f
by bm0p700f
What you did on the DT Swiss hubs kode54 is not a a service as such. You pulled of the the freehub and renewed the star ratchet grease. A service to me is a bearing change. That is less easy in the rear hub.
kode54
by kode54
DT Swiss bearing change is not that easy, you're right. you also need the special tools to extract them.
never did that on the DT or Enve hubs.
bm0p700f wrote:
Sun Dec 09, 2018 10:16 pm
LeDuke
by LeDuke
kode54 wrote:DT Swiss bearing change is not that easy, you're right. you also need the special tools to extract them.
You need a special tool to extract one of the bearings. One. You will likely do this once or twice on the lifetime of the wheel.
RyanH
by RyanH
Freehub bearing replacement was easy, tap the bearings out and press the new ones in.
Regarding the Enve hubs, I hope they fixed the play issues.
kode54
by kode54
the bearing play was only on one of my gen1 carbon hub which Enve fixed. could have been one of the bearing races or bearing itself...but they replaced the entire rear hub according to their work order sheet that was returned with the wheel.
@bm0p700f ...good to know there's only one die tool needed for the bearings.
RyanH wrote:
Mon Dec 10, 2018 5:32 am
kode54
by kode54
kode54 wrote:
Mon Dec 10, 2018 2:30 pm
@LeDuke ...good to know there's only one die tool needed for the bearings.
MisterEd
by MisterEd
Had a pair of gen 1's replaced under warranty due to play, it was an issue with the hub rather than the bearings.
I'd heard that problems with them were fairly common so had them replaced with Chris Kings.
bm0p700f
by bm0p700f
Le duke. I dont care how infrequently a bearing has to be changed (there are many hubs that give long bearing life without proerpriety tools or have to remove the ratchet ring or ring nut in DT Swiss's case) it is needlessly hard although to make the ring nut bigger the hub weight would go up so I can see why they have done it that way.
bm0p700f
by bm0p700f
Actually once the ring nut is out you dont need DT Swiss's tools for the bearings. The wheels manufacturing bearing press and over axle kit deals with it.
