295g hookless disc rims? anyone used these?
bikebreak
by bikebreak
I got an old disc frame to build up, never built disc before
I like light wheels, so I went looking for the lightest disc rims and found these
https://www.aliexpress.com/store/produc ... 15222.html
same as
https://www.ebay.com/itm/295g-Super-lig ... 2450174364
Anyone built these? They ride well?
295g seems optimistic for clincher, but it is hookless...
siim
by siim
Max pressure of that rim is 60psi/4.1bar
If you run road tires, you will want to go above that, making this rim useless for road purposes.
bikebreak
by bikebreak
Yep, hookless would be tubeless only and I could get away with 50-60psi in a tubeless tire
Monkeyfudger
by Monkeyfudger
I thought hookless was only aimed at MTB?
joejack951
by joejack951
Monkeyfudger wrote:
Wed Nov 21, 2018 5:44 pm
Not any more: https://www.enve.com/en/products/ses-4-5-ar/
Global
by Global
Running that same setup 28 to 38 tires on my crux. Have used them tubeless with 28 Hutchinson on my tarmac with 75psi ( I know the max should be 60 psi). Working well so far. Did blow off rim when I accidentally put 110 psi in them. Now have about 5000 miles total on them. These were from carbonfan.
Global :)
ooo
by ooo
@Global, what was rim internal width?
Global
by Global
It’s been awhile ago I thought they were 22 ID but I see similar shows 23.
Global :)
Global
by Global
Some photos on the scale and on my tarmac. Also have roval clx 32s that broke and are being replaced by warranty. These will go back on my crux then.
Global :)
ooo
by ooo
thanks, now I have a plans to make front wheel with this rim.
have you measured actual tire width when you mount 28 Hutchinson?
Global
by Global
30.7 I believe there’s photos on a previous post about tubeless tires. Will take new photos later this week now that they are stretched out.
Global :)
Global
by Global
Found the old photo.
Global :)
MikeD
by MikeD
I wouldn't use a hookless rim on a road bike, no way, no how.
bm0p700f
by bm0p700f
I think this is a light bicycle rim if lb are the manufacturer.
