New wheels
spdntrxi
by spdntrxi
small
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
AJS914
by AJS914
1mm here or there isn't going to make a huge difference. I would work backwards from which tire you want to run and buy a rim with a width that will accomodate that and fit your frame nicely.
Cycleman
by Cycleman
So is better for 17c to use 23mm tyre?
AJS914
by AJS914
Better in which way? It just depends on your goals.
My guess is that on Campagnolo Boras (c17) most people are using a 25mm tire. I mean a tire that actually measures 25mm when installed. For example a 23mm Grand Prix 4000S measures out to 25mm. Some people probably use the next size up if it fits in their frame and they probably don't care about the few watts used up by a wider tire.
Whether you buy a 17mm internal rim or a 19mm internal rim is not going to make a huge difference. I have two wheelsets, one is 15mm internal and the other 19mm internal. I run the 23mm Grand Prixs on both (again, they measure around 25mm on the 15mm rim and 26mm on the wider rim). Both work fine. I get a little bit more volume on the 19mm internal rims. The difference is not earthshattering.
Like I said, start with the tires you want to run and work backwards.
Cycleman
by Cycleman
great details.thanx a lot my friend.
so what measure will i get with 23mm?!What in 25mm? lets say for 17c rim.
ultimobici
by ultimobici
AJS914 wrote:Better in which way? It just depends on your goals.
So I take it you think ETRTO guidelines are bunk?
bm0p700f
by bm0p700f
ertro guidelines on recommend tyre sizes are under review.
Besides what is a 25mm tyre anyway. Each brand and even each model have differing bead to bead distances.
ultimobici
by ultimobici
They may be under review, but overly narrow tyres on a wide rim are generally a bad idea unless your riding is on billiard smooth roads. The wider the rim, the more prone to pinch flats one will be.
Most tyres come up big rather than small. Veloflex is the only brand I can think of that seems to go the other way. The fact is that many race tyres currently on the market were designed with a particular internal width range in mind that didn’t take the trend to go wider into account because 17c rims were for touring. So while you can fit them to whatever rims you want, whether they actually perform properly is another matter. Just because a customer wants something doesn’t mean they should be given it.
Phill P
by Phill P
Cycleman wrote:
Sun Nov 25, 2018 8:18 pm
Well guys i am pretty disappointed.
I'm Looking for A wheel Costs 2000e with inner width 18 or more with 1400gr.
We have multiple wheelsets that meet this spec.
Technical Director at www.TUFFcycle.com
bm0p700f
by bm0p700f
As I said before op talk to. Wheelbuilder. 1400g wide and under 2000 euro is really quite easy.
bm0p700f
by bm0p700f
Ultombici I did give the specific example of the conti gp 4000s 23mm tyre. Not every 23mm tyre works on a wide rim I did say that but some do. Although I would not use the conti in anything wider than a 19mm internal width rim.
Since the bead distance if every 23, 25 and 28mm tyre is different the ertro chart really does not inform. If ertro standardised tyre width then there chart becomes useful again.
nachetetm
by nachetetm
DT Swiss has an "updated" version of the ETRTO that I think it is quite realistic. In my opinion, 19c internal is the most versatile width for my interest, from 25 to 32c tires. I am not sure I would feel comfortable using a 23c tire on that internal width. I know that HED says that 23c tires are ok on rims wider than 20c internal but I wouldn't risk it.
Cycleman
by Cycleman
guys i can't find that's 18c and over.that's for sure.
some wheels like bontrager etc had more grams than my fulcrum racing 3
bm0p700f
by bm0p700f
Talk to a wheelbuilder.
Here's one just for starters
The wheels in my look 785.
45mm deep, 18.5mm internal width weight 1280g.
It's so simple.
Another alloy set. Easton R90SL rim 24F/28r can be built sub 1400g with CX rays. you have to stop looking at off the shelf.
As I have said since there is no standard 23mm tyre e.t c charts like this make little sense. If they published bead to bead distance it would make more sense.
Davico
by Davico
If weight is your concern, ride tubulars. There ain‘t nothing like it. I ride Campagnolo Bora Ultra 35 (1160g) and Bora Ultra 50 (1215g). Hardly ever have flats, and I riding on less than perfect roads. The quality of the wheels can’t be beat, either. And no worries about internal rim width 😉
