Alloy braking surface aero wheelset
Hex
by Hex
Aaahh! Interesting! Gonna have a good look at these!
Thanks for the tip!
nafaiutb
by nafaiutb
Hex wrote:
Mon Sep 10, 2018 6:11 am
silvalis wrote:
Mon Sep 10, 2018 1:33 am
So just to understand, you want 19c because 25mm veloflexes on 19c = 28mm exactly?
Almost! 28mm Veloflexes will be 28mm on 19c
25mm Veloflexes are 25mm on my 19c rims!
Veloflex say the maximum internal rim width to use safely with their 25mm clinchers is 17c....
silvalis
by silvalis
Interesting.
So I guess if I throw some 25mm veloflex corsas onto some 17c rims (or even my old 15c R3s) they will come up smaller than expected and nowhere near the 26-27mm I get from other popular tyres.
That's a bit off putting, in the opposite direction to yours :lol:
Chasse patate
Stitchking
by Stitchking
Hex wrote:25mm Pro Ones.
On my wheels, 25mm Pro Ones are ~27.5mm when new, 28mm solid after about 300km.
25mm Veloflex come up to 25mm solid...bit shy of 25mm when new.
Do Plus rims really widen tires that much? That's about 5mm from spec.
I imagine that 25mm Veloflexes would behave like the 23mm Pro Ones
On my ardenne + wheelset i tried vittoria corsa, pirelli pzero velo, and conti ultra sport 23, schwalbe one tubeless and they all measured 26.99 new.
I test fit some 25 pro ones and they measured 29mm.
If you have tight frame tolerances i wouldn't reccomend going over 19mm wide as those tyres were basically stretched onto the rim at 23c, and you really want 25 or larger.
Honestly, i think choosing a rim Based on the fact that a veloflex tyre is measured at what it says it is on the sidewall is pretty pedantic. That probably just means theyre just measuring them to a different standard than everyone else and you could just size down on any other tyre and the carcass will be the same volume
Sent from my SM-G935F using Tapatalk
Hex
by Hex
Stitchking wrote:
Mon Sep 10, 2018 1:26 pm
On this post:
https://www.starbike.com/weightweenies/blog/?p=806
...on 21c, the 28c veloflex to come up to a bit more than 28mm, so I thought I might include the Zipp 30 course inside, but I think I'll play it safe and go with 19c as the widest internal.
It isn't about how veloflex measures/advertises the width of their tyres, it is about me getting the widest I can fit in my rim. When I rode the 25s, while nice, they were not as nice feeling as the wider tyres I can mount (meaning, the ones that measure 28mm or thereabouts mounted on my rims)
Tire volume is important for comfort, this is why I'm eyeing the 28mm Veloflexes now. I couldn't ride them for long because I have more comfy tires, but I love how they corner and accelerate and I'm certain I will love the overall feel at their widest possible.
Hex
by Hex
silvalis wrote:
Mon Sep 10, 2018 8:42 am
Interesting.
Just a different way of measuring/adversiting their width. The actual width is what matters and I think they want to offer "common 25mm" but going with their own measurements, so 28mm is what most of us consider 25mm tyres (from conti, michelin, schwalbe, etc)
Stitchking
by Stitchking
Iirc the tyre measurement standard is what they will inflate too on a 700x15 rim, hence why most brands end up wider than stated.
Hex
by Hex
Stitchking wrote:
Mon Sep 10, 2018 8:17 pm
I see! But then what would be the standard/measurement used by veloflex?
Not pointing or snaring, just wondering because they always come smaller than the more mainstream offerings.
Hex
by Hex
I've come across these guys recently:
https://www.uk.kinetic-one.com/carbonal ... s-94-c.asp
Anyone with experience on these?
MagicShite
by MagicShite
Hex wrote:
Sat Sep 22, 2018 8:48 pm
looks eerily the same as YEOLEO's carbon alloy wheels.
I'd say grab the YEOLEO's instead.
mpulsiv
by mpulsiv
Veloflex run true to size. The inner rim width irrelevant for these tires. The reason you want these on narrow rim is because of cotton casing (e.g. open tubular), sidewalls are not reinforced which put you in higher risk of tire rolling off the rim. I have been racing on 25mm Master. Fantastic tire but can’t wait to mount 28mm Master for 2019 season.
alcatraz
by alcatraz
A heavy friend of mine (95-100kg) running sram red brake calipers used to run alloy+carbon fairing bontrager wheels. When his rear wheel gave up its ghost and had to have it's rim replaced we after much consideration went with carbon. Knowing that the braking performance would be unimpressive he never got fully used to it and often thought about changing the whole bike and disc brakes.
Now a few weeks later it's less of an issue because he went through a couple of brake pads. Believe it or not but there is an ongoing evolution of brake pads with great progress. He switched to carbstop and says he can now lock his wheel in the rain if he wants. He stopped dreaming of disc brakes and now descends with confidence again. Another happy carbon all-weather convert. (I'd like to add that the reason his alloy rim had to be replaced was just because it was alloy soft and got too deformed.)
Hex
by Hex
mpulsiv wrote:
Sun Sep 23, 2018 6:17 am
I'm Def looking forward mounting the 28s for sure!
I did like my 25s, but never got to love them because they were not smooth enough like the more mainstream 25s (sizing up to 28) I ride.
I have another thread here on a inner tubes. It looks like latex is gonna win again because there isn't much else around to give a close feel to it.
Someone mentioned these new plastic tubes (tubolito/revoloop) but the feel seems not as smooth as latex.
Now thinking I'm gonna go latex w/ sealant to have some self repair ability.
Hex
by Hex
MagicShite wrote:
Sun Sep 23, 2018 4:01 am
Aha! Nice! Thanks! Looks like the difference is Kinetic-one give you more hub choice, but Yoeleo seems only slightly more affordable.
On that note, though, i'd have the cough up for VAT and possible duties once it lands in europe... :( leaves me with Kinetic-one as the only choice between the two.
Hex
by Hex
alcatraz wrote:
Mon Sep 24, 2018 2:15 am
I have indeed been looking into this. I have considered it. It does help I live in relatively dry and warm weather, making braking not much of an issue if any, but I may end up using latex tubes and Veloflex strongly recommends against using their clinchers with carbon rims.
