Lightest rim tape for carbon clincher
You have a point about glue, but once the tire is up to pressure, the tube is basically locked in place to the tire and rim. The tube doesn't move.LouisN wrote:QUESTION For normal clincher/inner tube application and using a tape with glue on it:
Won't the glue come out on the sides of the tape from pressure ? Thus, preventing the tube, like a latex tube, to move feely inside the clincher, becoming messy and all...?
Thanks for the heads up.
Louis
I ordered a roll and will give it a try.TobinHatesYou wrote: ↑Thu Sep 06, 2018 10:50 amPowder coating masking tape is superior to Tesa 4289 imo.
My LBS put two layers of gorilla tape in one of my 29er rims when I had them mount some new tires, which I didn’t find out about until I changed tires. According to them I needed a tighter fit for tubeless when I queried them later. I took the tape off and weighed it...+30g! Not only that, it leaves a glue residue that requires some time and effort to clean off. I put two layers of Stans tape on, saved +20g, and had no problem airing up and holding air with a compressor (which I didn’t have when I had the LBS do the work).
best width for tape? enough to cover up to the lip edge?
maybe i need to revisit the tubeless aspect and give it another go using powder coating tape.
ergott wrote: ↑Thu Sep 06, 2018 4:14 pmI ordered a roll and will give it a try.TobinHatesYou wrote: ↑Thu Sep 06, 2018 10:50 amPowder coating masking tape is superior to Tesa 4289 imo.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
I prefer it to reach at least edge to edge and if a little runs up the side of the wall that's okay. I don't want it to be narrower than the rim bed. If so I do one wrap up against one side and the second wrap against the other.
I prefer the tape ride up the sides slightly as well. Generally speaking helps ensure the tape doesn’t shift if the adhesive degrades over time. Also the tape in question only comes in fractions and multiples of 1” with 1” being suitable for 19mm rims and wider.
I generally try for at least 2mm wider than whatever the internal rim width is, but that’s not always available and I’ve gone as wide as 4mm wider (example, for my 21mm IW gravel rims I used 25mm Stans no problem).
First install today. I really like! Thanks for the tip!TobinHatesYou wrote: ↑Thu Sep 06, 2018 10:50 amPowder coating masking tape is superior to Tesa 4289 imo.
Which masking tape did you use?
Yeah, it’s thinner and conforms to rim bed center channels better than Tesa 4289. It’s stronger than something like Velocity Velotape (which I think is 3M 8898.) The adhesive is just right. It’s cheap and widely available. I haven’t actually weighed it, but I’m betting two layers is a fraction of a gram lighter than 4289...lol.
Credit goes to MTBR’s big tubeless tape thread. They seem to prefer Tyvek tape, but that stuff has to be cut down to appropriate widths.
great tip. thx.
That looks interesting. Can you tear it by hand? If so, I don't think it's strong enough.
- Similar Topics
- Replies
- Views
- Last post
option for wheels ? -> Tru-Axle, Disc, Carbon Clincher, No-Rim Tape, Tubeless
by ongbenghui » Sun Feb 17, 2019 3:04 pm » in Everything wheels - 5 Replies
- 220 Views
Last post by kode54
Wed Feb 20, 2019 12:17 am
- 11 Replies
- 389 Views
Last post by bm0p700f
Mon Feb 11, 2019 5:32 pm
- 1 Replies
- 259 Views
Last post by mag
Tue Oct 30, 2018 11:42 pm
- 9 Replies
- 1363 Views
Last post by TonyM
Thu Apr 19, 2018 4:53 pm
Apply for tubuless into normal clincher carbon rim
by apricotwalnut » Sun Mar 04, 2018 3:05 pm » in Everything wheels - 4 Replies
- 441 Views
Last post by IrrelevantD
Wed Mar 07, 2018 8:10 pm
