Kenda Valkyrie Pro 700x25 120TPI 125PSI Road Bike Tire 700 x 25 214002 125PSI
- WinterRider
Anyone tried this rubber? Listed at 180's wt.
Litespeed 2000 Appalachian 61 cm
Litespeed 1998 Blue Ridge 61cm
Fitness rider.. 1 yr from seven decades age.
That is my story and I'm stick'n to it.
I've been using them for a year. Real weight for the 25's is about 195 g. I switched to them from the conti gp's because I was getting so many flats, oftentimes from sidewall cuts. I fared much better with the Valkyries. After about 2000 mi, I started noticing more cuts on the tread and then they were a bit more flat prone.
Because I tend to do long solo rides, I now use a Kenda Kountach on the rear wheel and the valkyrie pro on the front. If I wasn't going out on such long rides, I'd be running the valkyrie on both wheels.
Speedplay is the devil!
I'm using them, so far so good, the weight makes puncture less painful
