Hello,
where do I find the tiny grub screw (No. 6)? Do I have to remove the axle?
I expected it to be in the adjusting ring?
B.
Edit: the manual seem to refer to this model:
But it was this one:
Adjusting play of Carbon TI X-Hubs Road
Maybe you can just adjust it without tools - rotate with fingers
Thanks, yes it seems to be that easy. I will try again in the afternoon.
There has been an update of the preload ring and it can be replaced afterwards: https://r2-bike.com/CARBON-TI-Ersatztei ... Ring-X-Hub
Question is, if this is necessary as there have been problems with the old version and it will loosen again elsewise?
It is better with no tool i think
Older needs hex key -
The tension on the axles was quite low. I did 8 Nm (8-10 is recommended) and the play is gone. The bearings spin as easy as before.
It was the first adjustment after 1,000km or so - I hope it really stays now as it is.
The 1,5mm hex key is needed from now on - the finger adjustment is gone, if you buy new. But you really need to push very hard with your fingers on the old one.
