Adding Rim airfoils
WinterRider
by WinterRider
Aero rims.
Add an airfoil on existing rims. Designs could be complex.. not seen on molded rims. Your alloy rims too.
Simple. Cheap to manufacture. Not the bother of meeting strength criteria
rims do. Forget these 'molded games'.
Add me a teardrop shape to my "tall" Kinlin 200's.. give me a few watts.
These should weigh minor grams... effective trade for the benefits. Unlike the heavy clunking car-bon.
:beerchug:
Marin
by Marin
Wow I wonder why noone had this idea before
WinterRider
by WinterRider
Marin wrote: ↑
Tue Jul 17, 2018 1:14 pm
:noidea:
Have NO issue w the 21st century types spending all that coin on the plastic molded stuff.. great for the economy moving the cash around. Well done in fact. Cool too.
Butttt... adding a foil on the rim would open up real experimentation beating the wind.
WinterRider
by WinterRider
Marin wrote: ↑
Ooops. Doop-li-cate.
NiFTY
by NiFTY
Marin was being sarcastic. Cause a lot of people have done this before. Heck the HED disc wheels are just a carbon skin over a spoked wheel.
bremerradkurier
by bremerradkurier
Around 1990 there used to be faux disc wheel covers with a alloy hoop clipped to the spokes supporting a stretch nylon cover.
alcatraz
by alcatraz
I think one problem is that the brake tracks can't be covered. The airfoil would be broken there and it's a crucial place. :?
Another is that it might be hard to attach it without it coming loose
Thin plastic warps in heat. I had some covers that were not allowed to go over 80 degrees which means no direct sunshine in the hot summer. They were also very heavy at 500gr/wheel. They were full covers though.
Never got to use them. Only one ride. Worked fine but the bike felt quite sluggish. :)
AJS914
by AJS914
bremerradkurier wrote: ↑
Thu Jul 19, 2018 7:23 pm
I had those around 1992. I used them one time in a TT.
WinterRider
by WinterRider
Secure attachment of any aero device I think is the main limiting factor... potential profit margins I think a nice apple. No need for strength either.. the material could be very light.
Lots of improvements to be had fishin' to remove the last few watts.
mattr
by mattr
Secure attachment is what adds the weight. As they need to be *really* secure. The thought of having a poorly secured ring of plastic or composite on your wheel at any speed is terrifying.
Which is eventually/essentially what's killed them.
Heavy, lack of compatibility (need to fit a broad range of rims, properly.) And just not that aero.
Carbon does it better.
TheKaiser
by TheKaiser
That would probably be the Unidisc you are thinking of. It came in both a lycra model, and a rubberized lycra model that resisted dirt and grunge better than the straight fabric model. I even remember guys riding off road with them, back when Tioga tension discs were the coolest thing, so they clearly had their secure attachment game dialed in.
F45
by F45
You can secure it with a lightweight polymer backed adhesive that is already on the market.
WinterRider
by WinterRider
F45 wrote: ↑
Mon Jul 23, 2018 12:18 am
Suggest.. that is what killed these. Glue always fails... just a question of when.
