Light Bicycle wheel rims?
The new braided weave looks nice, anyone got this yet?
https://www.lightbicycle.com/photowall/ ... e-Rim.html
Is there much point in getting CX Sprint drive side or better off just doing CX Ray all round? Will be 24/24 on carbon Ti hubs.
One last thing - I've selected hooked rims which seem like they don't really have a downside compared to hookless, can anyone confirm that's the best option?
- musiclover
No, it's not that simple. Each option has downsides. LB do not like to sell hokless though as they are less foolproof. I run hookless and they are better for my situation.steamroller wrote: ↑Fri Sep 24, 2021 1:06 amOne last thing - I've selected hooked rims which seem like they don't really have a downside compared to hookless, can anyone confirm that's the best option?
My YouTube channel https://www.youtube.com/channel/UC3_EMN ... tPAm4Md1bQ
Hooked gives much more flexibility in terms of tyres you can use, basically any tubeless or clincher tyre. Whereas hookless is only certain tyres, with potential for the tyre to blow off the rim.steamroller wrote: ↑Fri Sep 24, 2021 1:06 amOne last thing - I've selected hooked rims which seem like they don't really have a downside compared to hookless, can anyone confirm that's the best option?
In theory hookless should make a lighter and stronger rim with better aerodynamics. However I would be getting hooked for Road wheels
I agree. Hookless is better in theory. But there is too much inconsistency with tyre and wheel sizing, and this in reality you get a situation like Giant has with their TCR rims, where there is a very limited list of tyres that can be used.TwiggyForest wrote:Hooked gives much more flexibility in terms of tyres you can use, basically any tubeless or clincher tyre. Whereas hookless is only certain tyres, with potential for the tyre to blow off the rim.steamroller wrote: ↑Fri Sep 24, 2021 1:06 amOne last thing - I've selected hooked rims which seem like they don't really have a downside compared to hookless, can anyone confirm that's the best option?
For wider tyres the pressures used are lower, the chance of the tyre blowing off a hookless wheel are low. The higher strength of hookless beads is also good for rougher roads where a rim strike is more likely.
For these reasons I use hookless for allroad and gravel, and hooked for road.
Listen to this month's Cycling Tips interview with ZIPP product manager. He says that with the proper tire that hookless has nearly identical holding power as hooked rims. The only reason why they agreed with the ETRTO stanard of a max tire pressure of 70psi for hookless rims were the riding advantages of lower pressure... e.g. rolling resistance, comfort, etc.
https://cyclingtips.com/2021/09/nerd-al ... confusion/
I agree, rhough, that there are much fewer acceptable rim / tire combos with hookless.
2018 Fuji Transonic 2.5 rim (7.51kg)
2020 ICAN AC-388 cyclocross bike (8.41kg)
2021 Trek Emonda SLR RSL rim (5.65kg)
1980s vintage ALAN Super Record (haven't weighed it)
A Guy from Zipp, who sells almost only hookless rims these days, tells us that hookless is better. D: yeah, sure.choochoo46 wrote:Listen to this month's Cycling Tips interview with ZIPP product manager. He says that with the proper tire that hookless has nearly identical holding power as hooked rims. The only reason why they agreed with the ETRTO stanard of a max tire pressure of 70psi for hookless rims were the riding advantages of lower pressure... e.g. rolling resistance, comfort, etc.
- musiclover
Exactly, hookless is better with a tyre that works with hookless. As I found out Conti GP5000 do not but Schwalbe Pro ones do.
That's why I said above "hookless is better for my situation" and by a "situation" I meant good tyres.
Ended up going WR50s flyweight with Carbon-Ti hubs, hookless, drain holes and 24h/24h CX Rays. It's only been a few days but they are already at the sanding stage. Will post some pics when I get them if anyone is interested. Now to find some XT centrelock rotors...
i have the WR50's on DT Swiss 180 hubs, built them myself and run them with Enve 29 tyres. Amazing set of all round wheels. I think ive noted before have been buying LB wheels for the best part of 10 years and all still running strong.
re hubs - It's mostly a metter of weight and maintenance
Thinking of this setup for my WR50’s when I next replace my tyres. How wide do the Enve 29’s measure on the WR50’s?mashiehood wrote:i have the WR50's on DT Swiss 180 hubs, built them myself and run them with Enve 29 tyres. Amazing set of all round wheels. I think ive noted before have been buying LB wheels for the best part of 10 years and all still running strong.
30.5-31mmemotive wrote:Thinking of this setup for my WR50’s when I next replace my tyres. How wide do the Enve 29’s measure on the WR50’s?mashiehood wrote:i have the WR50's on DT Swiss 180 hubs, built them myself and run them with Enve 29 tyres. Amazing set of all round wheels. I think ive noted before have been buying LB wheels for the best part of 10 years and all still running strong.
measure up to 33 depending on tyre pressureemotive wrote: ↑Fri Oct 01, 2021 11:59 amThinking of this setup for my WR50’s when I next replace my tyres. How wide do the Enve 29’s measure on the WR50’s?mashiehood wrote:i have the WR50's on DT Swiss 180 hubs, built them myself and run them with Enve 29 tyres. Amazing set of all round wheels. I think ive noted before have been buying LB wheels for the best part of 10 years and all still running strong.
