What type of maintenance does the carbon ti requires? I've read that these are more of a "summer hub".choochoo46 wrote: ↑Thu Jul 15, 2021 2:57 amI got the 36T DT350s on my AR56s rather than the DT240s. $100 less but 100g heavier. If I had to do it again it would be a coin toss. In my most recent set of wheels (EIEcarbon) I got the weight weenie Extralite Cybers (rim brake). If I were to buy LB wheels again, I'd probably go with Carbon Ti, which don't need special tools for maintenance.
Light Bicycle wheel rims?
Forum rules
As the other poster said it looks like their "raw/paintless" finish with unidirectional carbon. If you need to have a painted clearcoat in my experience a satin paint finish is probably the closest to this.
I mounted my gp5ks without levers. Slow and steady. Id hate to do it on the side of the road though.scatsob wrote: ↑Sun Jul 11, 2021 1:44 pmAnyone have issues getting GP5Ks in WR rims? Their website said it could be done without leavers and that is not my experience at all. I had my first flat out in the wild and I got worried I would need to call for a ride. Just curious.
- jagheterjan
Archetypes are bomb proof and would look the part polished.
Check out all the other WW postings on Carbon Ti. Looks like they now use sealed bearings. Seems like a perfect combo for your summer or race wheels. Hub can be loud though.pmprego wrote: ↑Thu Jul 15, 2021 7:36 amWhat type of maintenance does the carbon ti requires? I've read that these are more of a "summer hub".choochoo46 wrote: ↑Thu Jul 15, 2021 2:57 amI got the 36T DT350s on my AR56s rather than the DT240s. $100 less but 100g heavier. If I had to do it again it would be a coin toss. In my most recent set of wheels (EIEcarbon) I got the weight weenie Extralite Cybers (rim brake). If I were to buy LB wheels again, I'd probably go with Carbon Ti, which don't need special tools for maintenance.
As I mentioned before I like the fact you don't need special tools for maintenance for the Carbon TI hubs. And they're very light.
I have the 18T DT350s on my cross bike and 36T DT350s in my training wheels. Have thousands of miles in each with no maintenance needed except greasing the rachets - which is easy to do. To change the bearings of the DTs you need the special tools.
2018 Fuji Transonic 2.5 rim (6.90kg)
2020 ICAN AC-388 cyclocross bike (8.41kg)
2021 Trek Emonda SLR RSL H1 rim (5.65kg)
1980s vintage ALAN Super Record (haven't weighed it)
Nice! about to pull trigger on pretty much same build but carbon-ti hubs. Keen to hear what you think when you've put some miles on them
- musiclover
How do you know when to grease the ratchets?choochoo46 wrote: ↑Sat Jul 17, 2021 12:57 amI have the 18T DT350s on my cross bike and 36T DT350s in my training wheels. Have thousands of miles in each with no maintenance needed except greasing the rachets
I have retired from this forum, not wasting any more time here.
Any ride reviews yet on the AR 465 with X-flows? Particularly interested as far as they’re susceptibility to crosswinds.
On their website about the x-flow profile:
The wave style X-Flow rims feature a reduced aero drag, boosted lateral stiffness, and greater impact resistance, compared to our traditional design road rims. We sent several R and AR counterparts along with the newly designed X-Flow rims for comparison, to a third-party testing institute using Computational Fluid Dynamics (CFD). Based on the samples tested, removing crosswinds from the equation for a fair comparison, the X-Flow rims perform the best.
Are they saying they suck when taking into account crosswinds?
Essentially they're saying they suck in anything that isn't a 0 degree headwind or 180 tailwind ...vongarces wrote: ↑Sat Jul 17, 2021 2:56 amAny ride reviews yet on the AR 465 with X-flows? Particularly interested as far as they’re susceptibility to crosswinds.
Any 'fair comparison' of aero drag on rims / wheels includes multiple yaw angles and ideally speeds too.
Actually, they are probably not saying that. I think they didn't have access or didn't want to pay for testing in a place where different yaw angles were possible. There is no logical reason to assume the wheels perform worst than a similar standard rim. If that would be the case then the zipps or Princeton would also have a similar problem.
Why would you assume that? The Zipps and Princetons are variable depth, the LB rims have variable width with constant depth. You can't draw any conclusions about the X-flow design from the Zipp or Princeton designs; they are not similar.pmprego wrote: ↑Sat Jul 17, 2021 1:28 pmActually, they are probably not saying that. I think they didn't have access or didn't want to pay for testing in a place where different yaw angles were possible. There is no logical reason to assume the wheels perform worst than a similar standard rim. If that would be the case then the zipps or Princeton would also have a similar problem.
I understand that. Yet... If Zipp says "this is inspired in Wales" people will say "awesome" but if a Chinese company says what they said it is not believable. Just as specialized saying it's x amount of seconds faster. Or any other brand saying that their wheels are faster than the competition. All of those are claims that cannot be really verified.garbageman wrote: ↑Sat Jul 17, 2021 9:53 pmWhy would you assume that? The Zipps and Princetons are variable depth, the LB rims have variable width with constant depth. You can't draw any conclusions about the X-flow design from the Zipp or Princeton designs; they are not similar.pmprego wrote: ↑Sat Jul 17, 2021 1:28 pmActually, they are probably not saying that. I think they didn't have access or didn't want to pay for testing in a place where different yaw angles were possible. There is no logical reason to assume the wheels perform worst than a similar standard rim. If that would be the case then the zipps or Princeton would also have a similar problem.
But one does however he/she/they wants.
In my case, I try to get averages. If people with the X-flow 375 or 465 can confirm inner width, hook width and maximum width I'll be more than fine. On top of that which tires are using and their real measured width than it's just perfect.
The same goes for the wr40.
