Zipp 202 or 404 for everyday?
HarrisonK
by HarrisonK
I'm looking at buying either the 202 or 404 clinchers to use everyday. Are these wheels durable enough to be used everyday? The roads in my area are generally well maintained. Do you recommend the 202 or the 404?
mrlobber
by mrlobber
Why exactly Zipp?
But for everyday, 404 definitely.
Unless you ride in the mountains, in which case carbon clinchers are a bad idea, choose either solid aluminium wheels or tubulars.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
HarrisonK
by HarrisonK
I'm not set on Zipp specifically, but I have a good deal on a set of 202s or 404s. I'm open to anything, although I can't afford Lightweight or Enves. With that said, I'd like to find something similar to the 404's (around 50mm) but lighter. Any suggestions?
Beaver
by Beaver
mrlobber wrote: ↑
Thu Jun 14, 2018 3:08 pm
Have you seen a single destroyed carbon clincher with textured brake tracks (e.g. Zipp showstopper)? ;)
That argument is not valid anymore but still in the heads. ;)
Noctiluxx
by Noctiluxx
Skip both and get the Bora Ultra 35 or 50. I had the Zipp 404 NSW's, the higher end version of the brand. While the wheelset was excellent, they lacked the stiffness, quick engagement, and abilities to deal with cross winds as my Bora Ultra 50's.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2016 Specialized Allez DSW Sprint (Gold)
mrlobber
by mrlobber
Beaver wrote: ↑
Thu Jun 14, 2018 5:09 pm
One of my buddies (who rides 20k+ year, though) recently melted one somewhere on Etna. But that was a Chinese rim, although endured several ten-thousands already.
Then again, I'm rather afraid of a blowing clincher sidewall than rim meltdown, which out of all wheel types carbon clinchers have the highest risk for ;)
HarrisonK wrote: ↑
Thu Jun 14, 2018 3:42 pm
Go for Boras then. And actually cheaper than Zipps, it think, too. I've got a 10+ years old set of original Bora Ultras, still running as smooth as new ones.
HarrisonK
by HarrisonK
The Bora's are over $1,000 more than the Zipps. I definitely cant do that. Any other suggestions?
Kurets
by Kurets
It really depends on what you like. I have a set of 202s and a set of Vision Metron 55s which I would say is quite similar in terms of depth at least. Out of these I prefer riding the 202s because I enjoy how snappy the bikd feels with the lighter wheelset. Sure, deeper is faster but outside of TTs I can't say that I think aerodynamics is that important, for racing at least.
Sent from my H4113 using Tapatalk
Beaver
by Beaver
mrlobber wrote: ↑
Thu Jun 14, 2018 7:05 pm
Chinese rims have either a basalt coating (smooth black surface) or a carbon-basalt weave (newer models). The first ones were really easy to "kill", with the newer ones it's already quite difficult. But the textured brake tracks of the big brands are really one step forward, they will eat up pads faster, but these will be very difficult to melt:
I never experienced a clincher sidewall blow, did it happen to you? And if, under what circumstances? Clinchers are so popular today, if that was an issue we would read a lot about it here. ;) And with todays wider rims, really high pressures are no longer needed, too.
Beaver
by Beaver
HarrisonK wrote: ↑
Thu Jun 14, 2018 7:21 pm
Bontrager XXX 4 or Roval CLX 50?
Noctiluxx
by Noctiluxx
HarrisonK wrote: ↑
Check Merlincycles.com
The Ultra 35's are $1800 while the 50's are $2300.
nkanaf
by nkanaf
HarrisonK wrote: ↑
Thu Jun 14, 2018 2:29 pm
Much hype surrounds these deeper section carbon wheels, but I have always found them less stable for every day use in cross winds. I have Zipp 303 firecrest disc wheels and wish I had the 202 instead. I highly recommend 202, especially if you are a smaller rider like me
TobinHatesYou
by TobinHatesYou
nkanaf wrote: ↑
Thu Jun 14, 2018 11:15 pm
I like my 202s more and more every day since it seems like extreme winds are the new norm in the Bay Area as climate change continues to mess with ocean currents.
springs
by springs
I've been riding 202s everyday for the past four or five years. In the mountains.
Noctiluxx
by Noctiluxx
If I was limited to one set of wheels, they would be carbon clinchers in the 35-45mm range.
