So it’s not apples to apples but, it’s a comparison with the same tire. With the Hed wheels the tire balloons out to 28 plus as opposed to the FSE wheel the tire stays at 25. There is a noticeable difference is comfort in the added 2.54 cm. Also I think the Hed is more stable at power. Yes, the FSE is stiff and responsive. Also there is a noticeable aero pull. I can’t really talk about braking until the EE brakes are on. What is everyone else’s thoughts.
Hed Ardennes Sl+
FSE 45 EVO
Wheels: Aero, 170 grams lighter, and thinner or thick, more stable, and bombproof?
The FSE will have a one digit watt benefit at 45kmph (450 watts needed overall in the drops) - so not really noticable. But they should be more stable in crosswinds despite the higher rim (what do you mean by aero pull?). The HED will allow you to run a much lower pressure without sacrificing tire performance though. Best of both worlds would be a rim with 21mm inside and at least 28mm outside.
Its hard to explain but, these feel like a sail sometimes.
That’s called the placebo effect! (The aerodynamic gains of the deeper wheel will be so small as to be unnoticeable at any given moment.)
