Disc brakes - swapping wheels without ANY adjustment to brakes/mech etc.
TonyM
by TonyM
How much would you charge for one or two sets of shims to Europe/ UK?
NovemberDave
by NovemberDave
I checked Germany, Italy, France, and England and they are all $15 shipping for one or two packs of shims. That's $2 more than the product costs.
pushstart
by pushstart
Shimming is pretty dead simple. I use the Syntace shims since my hubs are 6-bolt. I have 3 sets of wheels for my gravel/commuter and do not need to adjust my brakes when swapping wheels. There is one wheel that requires a few clicks of RD tension adjustment, though.
Estafeta
by Estafeta
We are giving shipping service between the USA to Mexico. If you want to ship your goods, please call us and give us your order we will ship your goods safely.
MLM shipping
Svetty
by Svetty
I'm going to try modifying an inboard 1mm Shimano 10sd cassette spacer. The diameter just needs enlarging a smidgen to clear the CL spines.
The trick will be reducing the thickness evenly - assuming the shim needs to be less than a full mm.
C36
by C36
Edit
Svetty
by Svetty
Update: I can confirm that the cassette spacer works fine with a slight enlargement of the hole. Luckily the thickness was spot on for me to now swap wheels without the disc rubbing. Funnily enough the rear didn't need shimming....
billythestickboy
by billythestickboy
Resurrecting an old thread but I've managed to shim the wheels on my bikes now. Just wondering if people do anything about the pads? To they need bedding in again or should I maybe be switching the pads over?
IrrelevantD
by IrrelevantD
billythestickboy wrote:
Sat Jun 06, 2020 11:53 am
I don't do anything. I have 4-1/2 sets of wheels for my bike, I just swap and go. Never been an issue. Hydraulic brakes are pretty good about adjusting to minor differences in rotor offset, and I've never had any issues with pads.
billythestickboy
by billythestickboy
Cool thanks.
