Carbon Wheels - Brake Track Wear
Dannnnn
by Dannnnn
I recently bought a pair of Cosine 45mm wheels off another forum (Sold as "as new")
So far they have been great and I really like them.
Last week I went out and got caught in the rain. When I got home I saw that both wheels were covered in a white powder/solution.
I assume that this was where the resin has been wearing away whilst braking in the wet (like aluminium rims shed black powder/liquid).
So the next day I cleaned them and upon inspection of the brake track they look like the pics below in places.
My question is how badly worn do these look?
I read that when you start to see the carbon weave that they are almost done.
I only weigh 70kgs, the bike is 8kg and I'm using the Cosine supplied Carbon pads. I've been very careful with how I brake on them so I don't create too much heat (not that I do much braking on my training routes)
Thanks
sungod
by sungod
is the brake track deeply worn? i.e. concave or 'rutted', you should be able to feel this by running your fingers over the surface
generically, wear is not as simple as being able to see the weave - with some you can see the weave in brand new unridden wheels, and the weave is a normal part of the braking surface
if you're concerned, try contacting wiggle and see what their advice is for assessing wear
guyc
by guyc
That looks like they’ve scored. Something caught between pad and rim?
kode54
by kode54
grit on the road act like sandpaper on carbon. some rims wear more than others.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
Dannnnn
by Dannnnn
sungod wrote: ↑
Mon Apr 30, 2018 5:19 pm
Nope, the brake track is still smooth. There is a slight groove in them but it's not massively noticable.
I'll give wiggle a shout and see what they say.
alcatraz
by alcatraz
Were the brake tracks much less scratched before the ride in the rain?
Seems like you have a lot of debris in the pads. Better clean them out and reduce your rain riding.
You might also choose a softer pad. Take care when choosing though as many pads aren't suitable in the wet.
Is it possible the pads themselves are very abraisive? That would significantly lower the rim life span.
How about barradine blue. Oz cycle on youtube recommends them, affordable all weather pads. His rims passed 20.000km with those pads.
/a
wingguy
by wingguy
Dannnnn wrote: ↑
Mon Apr 30, 2018 11:22 am
Where did you read that? It’s impossible to make a generic determination like that across multiple brands of wheel. It may or may not be true of some wheels (though tbh I’d be surprised if it held for any) but as mentioned above, there are huge differences in the way braketracks are made.
Some manufacturers actually machine away the external resin layer to leave the carbon threads exposed from day 1, as it provides a grippier surface.
