ENVE 4.5 AR DISC VS Roval CLX 50 DISC
For the build up of my Tarmac SL6 disc I just need to make a dissicion about the wheel set.
- Or it's gonna be the ENVE 4.5 AR Disc with the DT-swiss hub.
- Or it's gonna be the Roval CLX 50 Disc
My dealer is gonna give me the same price for the wheel sets.
Where I'm gonna use the wheels? I live in Belgium, Flanders, so it's gonna be used on the Flanders roads.
Wich one would I pick for my SL6 disc
If you want to run 28mm tires Enve (25mm inside), for 25mm tires Roval (21mm inside).
28mm tires will be faster if your average speed is below 35km/h or you have very bad roads.
The official Tarmac SL6 disc tire clearance is for 30mm tires, so it should be real 40mm.
A Conti 4000S II 28mm (the widest 28mm I know) will be 34mm on the 25C Enve - 3mm clearance should be enough, if you avoid mud.
If not, you can pick a narrower 28mm tire like the GravelKing.
Will 28mm be slower at high speed?
Can you use normal tyres on the enve’s or only tubeless?
- Similar Topics
- Replies
- Views
- Last post
- 6 Replies
- 2088 Views
Last post by scale29
Wed Jul 25, 2018 6:09 pm
- 2 Replies
- 1808 Views
Last post by moonoi
Wed Jul 18, 2018 4:26 am
- 4 Replies
- 289 Views
Last post by KevinM
Fri Nov 23, 2018 4:44 am
- 4 Replies
- 542 Views
Last post by 1llum4
Fri Nov 02, 2018 7:25 am
Bontrager Aeolus Pro 5 vs Roval CL50 Disc
by FignonsMissing8Sec » Sun Jan 20, 2019 10:04 pm » in Road - 5 Replies
- 547 Views
Last post by morganb
Tue Jan 22, 2019 3:13 am
