Bora WTO
itsacarr
by itsacarr
Aren't the boras and fulcrums the same internal width. You liked the fulcrums better though?
jlok
by jlok
itsacarr wrote:
Mon Jul 27, 2020 12:10 am
In terms of traction and comfort, yes; climbing, no as the 45 has more snap.
srdrmrs
by srdrmrs
hi to all.
ı have two bike. one of them is viewtopic.php?f=10&t=162206&p=1581038#p1581038 the other one is allez sprint.
ı would like to use a deeper wheel for my allez. ı was thinking about wto 45 , ı only use prime 50se and i did 20k with that wheels. now ı would like to go upper class..
what you suggest for me?
RedRacer
by RedRacer
Currently riding Bora One 50 clincher pre-AC3 brake track with 25C tires and seriosuly considering moving to WTOs for three reasons. 1) Hoping they are even stiffer than the Boras. 2) AC3 braking 3) Maybe they will be more aero/faster. I don't plan to run tubeless.
My typical ride ratio is 100km / 1500m with most climbs being less than 10% and less than 8km in length. I weigh 82kg and punch better than I climb, therefore leaning towards the WTO 60s. Has anyone verified that they are really only ~50g heavier than the 45s?
Catagory6
by Catagory6
RedRacer wrote:
Tue Aug 25, 2020 12:15 am
i have AC3 and regular brake track. can't tell any difference at all
kevinw
by kevinw
Kristoff was back on WTOs for his tour win apparently - but the 45s rather than 60s
https://www.campagnolo.com/UK/en/CampyW ... ce_stage_1
jgpallero
by jgpallero
Hello,
Anyone riding Bora WTO with 23 mm tyres? Although the inner rim measure is 19 mm Campagnolo says that the WTOs are designed also for 23 mm tyres. Also, the exterior rim measure of 26.5 mm makes the rim wider than the tyre (23 mm at 8 bar actually produces a measure of about 24 mm in Continental GP 5000), which is optimal from the aerodynamic point of view. Is it safe to use a 8 bar pressure with carbon Boras?
Finally, if someone uses 23 mm tyres with WTOs, could please upload some photos?
neeb
by neeb
I'm using 23mm conti 5000 with WTO 33s - they measure almost 25mm at 90psi when fitted and look fine. Only one ride yet. Will try to post pics soon.
pdlpsher1
by pdlpsher1
Running a narrow tire on a wide rim you run the risk of exposing the tire's sidewall to road debris. You might get ride-ending tire sidewall cuts.
Sent from my KFMAWI using Tapatalk
sfo423
by sfo423
Are the WTO 45 disc optomized for 25 or 28 tires?
jgpallero
by jgpallero
sfo423 wrote:
Sat Sep 05, 2020 1:22 am
According to Campagnolo, "The profile of the rim, which has an internal diameter of 19 mm, corresponds perfectly with 23 mm, 25 mm and 28 mm tyres" (https://www.campagnolo.com/US/en/Wheels ... disc_brake, the same text is present in all the WTOs description)
According to Hambini, "It is vitally important to install tyres that are slightly narrower or inline with the brake track of the wheel rim", and "At speeds above 30km/h, it is more beneficial to have 23mm tyres than 25mm front tyres for aerodynamic benefit" (https://www.hambini.com/testing-to-find ... le-wheels/).
So for the WTOs, rim or disc brakes, the best choice from the aerodynamical point of view should be 23 mm or 25 mm tyres
bobones
by bobones
I've got a few hundred miles on my WTOs with 23 mm Corsa Speeds. No problem and they look good. I'll post a photo and measure them tomorrow, but I run them at only 5.5 bar.
neeb
by neeb
Here's mine - as above, these are 23mm conti 5000s at about 6 bar - they measure practically 25mm fitted, so about 1.5mm narrower than the external rim width.
jgpallero
by jgpallero
Thank you for the photos, @neeb. Only one detail: I think you have installed the tyres reversed. Well, Conti GP 5000 are almost slicks and I think the pattern does not play an important role, but at least the front tyre is reversed.
Other question: are the spokes in the WTOs round? They appear round in the pictures
neeb
by neeb
jgpallero wrote:
Sun Sep 06, 2020 1:08 am
Yes, you're right - the front was on backwards. TBH I'd no idea (or had forgotten) that the Contis were directional, coming from Vittoria Corsas and Schwalbes.. The directional arrow is pretty subtle and only on one side. I guess those little tread patterns might be 0.5w more aero the other way around.. :D .
No, they are smoothly ovalised - unlike the bladed spokes on the older Boras. I guess that the WTO spokes are oval in cross section while the older Boras are rectangular in section.
With my calipers the WTO spokes seem to be about 1.9mm x 1.3mm.
