Bora WTO
Forum rules
PoorCyclist
by PoorCyclist
WTO 45 rim brake, Shimano, weighted 1520g. I think 1496 claimed weight, Is that about average/normal with grease and Shimano freehub?
heard some piece of grit / debris from manufacturing inside the rim (both), after vacuuming seems to have gotten it out.
PoorCyclist
by PoorCyclist
did anyone have trouble getting sealant into the tire through the supplied valve and extender? The injector tube can go into the extender part only but not reach the tire, because the extender narrows down inside.
Has anyone successfully used another one piece valve?
bobones
by bobones
I never bothered with the extenders. Any valves long enough will do. I have used Milkit and Wiggle's Lifeline branded ones.
neeb
by neeb
PoorCyclist wrote:
Mon Dec 20, 2021 11:19 pm
I think that's a good weight. Mine are 1516g (665g + 851g), but I was lucky I think. Plenty of people (like Pukutis above) have weighed theirs in the 1540s.
The hubs (Shimano white hub vs. Campagnolo) are practically the same weight, Shimano hub maybe 2 or 3g heavier.
PoorCyclist
by PoorCyclist
I was able to fill milkit thru the extender. It's seems a little thicker than stans with some particles.
Pirelli tire goes on by hand, bead set but won't hold much without sealant, once the sealant worked around seems to be holding now.
My front rim is a bit off, does anyone know if Campy publish the tension value for the WTOs?
The front wheel is radial laced so would you trust taking it to any bike shop or only trust a Campy dealer?
jlok
by jlok
PoorCyclist wrote:
Tue Dec 21, 2021 9:53 pm
I had the same problem with the Slime shite sealant as it seems to be clogging up at the joint. Changed to Orange Seal and it's no problem.
extrusionedwin
by extrusionedwin
the freehub inside lubricant sop
PoorCyclist
by PoorCyclist
extrusionedwin wrote:
Fri Dec 24, 2021 3:54 am
is this good or bad?
I notice my freehub have enough drag it moves my pedals forward on a stand (it is extremely quiet). I have never seen that on a wheelset before. But I think it will loosen up when the grease breaks down. Now I know where the 20g of grease of my set is
crlincoln
by crlincoln
Hi,
Does I currently have a set of WTO 45's and there are a few good deals around at the moment for the 60's.... Is this just post Christmas Blues.... and liking the idea of deeper rims... as I'm presuming real world I'm unlikely to spot much of a difference...
Anyone want to convince me otherwise?
Cheers,
MrCurrieinahurry
by MrCurrieinahurry
Where are the good deals on the 60s?
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
shotgun1
by shotgun1
crlincoln wrote:
Sat Jan 08, 2022 12:32 pm
Hi,
Cheers,
I've demoed 30s 45s and 60s throughout a year (lucky me, warranty replacement took sooooo long). I think 45s are the middle ground, best of both worlds, I was given a choice what replacement to get and I chose 45,
2021 Giant TCR Advanced SL0 Disc 6.8kg
2019 Specialized Allez Sprint Disc 7.9kg
2017 Festka Scalatore 5.375kg
Original account [shotgun]: memberlist.php?mode=viewprofile&u=10594
crlincoln
by crlincoln
MrCurrieinahurry wrote:
Sat Jan 08, 2022 2:02 pm
In the UK, Wiggle/Chainreaction are selling at £1500..
Bobbyc123
by Bobbyc123
45s and 33s are going on eBay direct from the UK distributor at £1399: https://www.ebay.co.uk/itm/165233431780
Probs won't find them cheaper than that when trade price is 1250 + VAT
saracen888
by saracen888
Bobbyc123 wrote:
Fri Jan 14, 2022 3:59 pm
That's a great price
NLC86
by NLC86
Bora WTO 45 or Bora Ultra WTO 45?
