Bora WTO
pdlpsher1
by pdlpsher1
Any Bora owners planning to upgrade to Shimano 12-speed? It appears that the 12-speed Dura Ace cassette requires a new freehub, one that is similar to the 12-speed MTB Microspline freehub but different in length and spline profile. Since the WTO is fairly new I would expect that Campy will offer a Microspline-Road upgrade freehub. I don't know if the axle needs to be replaced. The Shimano Microspline freehub has a smaller diameter than the HG freehub. So if the axle stays the same then the two bearings inside the Microspline-Road freehub would have to shrink significantly. I have two sets of non-WTO Boras. I've checked Campy's technical document and both the non-WTO and WTO use the same freehub. So I'm covered as long as Campy continues to support the WTO with new freehub standards.
MariusRO
by MariusRO
According to the rumors posted in the DuraAce thread, we'll have 11t as smallest cog so HG freehub not microspline ;-)
pdlpsher1
by pdlpsher1
MariusRO wrote:
Wed Jun 16, 2021 10:36 pm
Someone in the same thread said the Dura Ace cassettes will only come in the MS version, while the Ultegra will come with HG. Hence my question. I'd rather not use Ultegra if I had a choice. It looks like Shimano is trying to push MS. Those that don't care about MS can just use the heavier Ultegra cassette. Maybe this is a false rumor. But it appeared that someone was given that information and he shared it here.
dalex
by dalex
Cat6Barrister wrote:
Sun Jun 06, 2021 3:51 pm
Someone should write to campy and ask they sell 45/60 combos.
Since the wheels can be ordered separately, this is exactly what my LBS in Switzerland was able to sell me last year. It's proved the perfect combo for my needs :-)
Cat6Barrister
by Cat6Barrister
dalex wrote:
Mon Jun 21, 2021 3:36 pm
Damn...Unless I win the lottery tomorrow, I'll continue to remind myself this "hobby" already has me deeply in the red financially lol.
bruno2000
by bruno2000
pdlpsher1 wrote:
Thu Jun 17, 2021 12:18 am
Shimano will not push MS and 12speed cassette will fit an 11spd body...wait and see.
pdlpsher1
by pdlpsher1
bruno2000 wrote:
Wed Jun 23, 2021 8:03 am
Thank you! That's what I wanted to hear!
ArtifactsInMotion
by ArtifactsInMotion
Just picked up a WTO 45 Rimbrake pair with a Shimano/SRAM freehub:
Front: 657g
Rear: 855.5g
Total: 1512.5g (1496g advertised)
Delta from advertised: 16.5g/1.1%
Very satisfied with the weigh in.
'15 BMC TMR01 58cm, SRAM Force AXS, SRAM Red Aero 1x PM crankset, Bontrager Aeolus XXX4/6, Pzero TLRSL 24mm, Bontrager RSLVRC barstem, S-Works Elaston Power, DA9100 Pedals: 7.4kg
Cat6Barrister
by Cat6Barrister
I basically spent over an hour swapping out clincher gp5000 for vittoria corsa on one of my wheels the other day...If I knew how hard it is I would have just gone tubeless because theres no way on gods green earth will I be able to change a flat on the road.
ArtifactsInMotion
Question: are these spokes top-of-the-line for campy? They seem kinda... chonky. I would love to swap them for DT Aerolites or Sapim CX Rays but I have no idea if that's 1. possible 2. will mess up I'm sure some special sauce of Campy's spoke choice.
ultimobici
by ultimobici
ArtifactsInMotion wrote:Question: are these spokes top-of-the-line for campy? They seem kinda... chonky. I would love to swap them for DT Aerolites or Sapim CX Rays but I have no idea if that's 1. possible 2. will mess up I'm sure some special sauce of Campy's spoke choice.
It may be possible if you can find just the right length spokes with the correct head shape.
But the question is why? You may lose weight but likely compromise stiffness.
kevinw
by kevinw
ultimobici wrote:
Mon Jul 05, 2021 6:19 am
I also think the diamond shape of the spokes goes a long way to explain why the wheels perform so well in a cross wind.
ArtifactsInMotion
kevinw wrote:
Mon Jul 05, 2021 12:44 pm
Because I am as vain and emotional as I am a weight weenie 😅I like the look of thinner bladed spokes better, and hoping there would be a weight element gain to it as well, but if it makes the wheel shit to ride, then no thanks.
kevinw
by kevinw
Master-Ti wrote:
Sat May 22, 2021 6:53 pm
I have no problems mounting the pair of Vittoria Corsa tubeless-ready tires, 28mm rear and 25mm front. However when I inflate, the air leaks out under the tire bead without the tire beads snapping onto the rim bed.
I had the same issues with the Corsa Speeds and gave up on them. I have now managed to buy some of the Vittoria air liners and I'm pleased to report that they now seat with just a track pump 👍
Really pleased with the liners but don't think I would get them fitted with GP5ks on these rims - already a really tight fit.
Master-Ti
by Master-Ti
I tried all the suggestions posted above without success, so I temporarily rode the Vittoria Corsa G2.0 tubeless ready tires with inner tubes for two 30km rides, hoping this would soften the tires enough to allow them to snap into the tubeless grooves on the rims.
After 2 rides, it was then really easy to remove the inner tube on one side and have the opposite bead stay beaded in the tubeless groove. The tire was then really easy to inflate, with the re-installed bead snapping into place first try!
Makes me wonder whether I should have just left the tire out in the sun to soften up from heat first before trying to install. Perhaps worth trying the next time?
