Enve 4.5's - Cervelo S3
LesroyBuckley
by LesroyBuckley
Hi guys, just got my warranty replacent Enve 4.5 to replace my old 3.4 gen1's.
Cervelo S3 - 56cm
Zipp SL-Sprint stem.
Zipp SL-70 Aero bars - 42cm.
Enve 4.5.
Sram eTap group.
Dura-ace chainset with Stages gen2 pm.
What do you think?
moyboy
by moyboy
Wheel height complements the S series frame.
Is there a reason why you have a Pirelli on the rear and Turbo on the front?
LesroyBuckley
by LesroyBuckley
Good spot, it was actually all I had in the garage so not by design.
I used to use the specialized turbo tyre on the Enve 3.4's as they seemed very wide and the rear would rub the chainstays if i used a 25c GP4000 for instance. The Specialized are 24c which helps.
Bordcla
by Bordcla
I have the same bike (albeit in 58) with the same wheels. Great combo! Rides great and fast as hell! Enjoy!!!
markgoldstein
by markgoldstein
I've just picked up a second hand S3 frameset, so this thread has some great ideas for the build.
Did you have any problems with the eTap FD? I've read that on some pre-2018 S3's you can't mount it low enough to reach the chainset properly, especially if you use a 50 tooth big ring. What chainset are you using - 52/36?
Also, what's the total weight of your build?
eforce123
by eforce123
Id like to know as well
