Campagnolo wheels and freehubs
Current setup:
Chorus groupset 50/34 with Chorus 12-29 cassette on Campy Zonda wheels. Chorus RD is short cage (non HO version)
Can these work or would I need to buy the new HO 'long cage' version of Chorus RD?
i) Shimano 11-30 or 11-32 on Bora One 35 (with shimano hubs of course)
ii) Bora One with campy hub with Potenza 11-32
How much are these freehubs?
Can I buy a shimano hub Bora One and just interchange with my Zonda freehub when I need?
Factor Ostro VAM
viewtopic.php?f=3&t=171023
Colnago C60
F12 Rim
viewtopic.php?f=10&t=159065&start=15
Colnago C60
F12 Rim
Are sure about this?bm0p700f wrote: ↑Sat Apr 14, 2018 6:53 pmThe short cage mech you have should just about accommodate your new cassette.
The Zonda freehub is FH-BUU015 the Bora one uses a 12mm axle and uses the FH-BU015 freehub. Remove your freehub in the Bora if it is 12mm steel then these are the parts you need. I hold stock of these freehubs. Many other shops do as well.
Im checking Campagnolo Spare Parts catalogue:
https://www.campagnolo.com/media/files/ ... part_C.pdf
And i can see that Both Zonda and Bora use FH-BUU015
My Bora's one - 2010 - 2011 do have the 17mm axle and the FH Bo015X1 in my case because I run a Ultegra cassette on it.
https://www.amazon.com/Campagnolo-Freeh ... B00SSTC1MK
thanks guys
It looks like the simplest way is to buy Bora One with campagnolo hub and use existing Chorus 12-29 cassette on it.
When I want to use a 11-32 for holiday, I would just have to pay that bit more for the Potenza 11-32 AND get the Chorus HO (medium cage), saves buying a freehub which cost around US$60+ anyway
Factor Ostro VAM
Colnago C60
F12 Rim
Colnago C60
F12 Rim
- in the industry
- Contact:
got confused. It is the bullet one wheels that used the BU015 freehub. I should have checked my own notes on this rather than going by faulty memory. That why I write stuff down I should look at it.
The bora one does use the BUU015 freehub. The BO)15 is the alloy version.
