32h tubeless road rims
jekyll man
by jekyll man
The Open Pro's on my powertap wheels are getting to the stage where they're due for replacement, and at this point may as well go tubeless.
These are for UK winter use, so they have to be fairly cheap, and available.
Need to be 32h.
Suggestions or experiences please...
Official cafe stop tester
NickJHP
by NickJHP
Velocity A23s work for me. 18mm internal width. I've been running Schwalbe S-One 700x30 tubeless on them.
bobones
by bobones
DT Swiss R460 - sub £60 a pair delivered from r2-bike.de. 18mm internal, nice graphics, wear indicator, tubeless but standard tyre relatively easy to fit.
bm0p700f
by bm0p700f
Kinlin XR22T is the best of all of them.
Multebear
by Multebear
I have good experience with the DT 460 as well. Inexpensive, easy to build and ride well. Haven't tried them tubeless tho...
morganb
by morganb
Everything suggested so far are great rims. The XR26 and XR31 are also good and a bit heavier/beefier if you want a stiff wheel.
jekyll man
by jekyll man
Cheers for the replies, will take a look at the DT's first :)
Miller
by Miller
What about the new Open Pro UST rims?
dim
by dim
bm0p700f wrote:
Mon Mar 05, 2018 12:28 am
Malcom, I might be interested in these rims (if they are for disc brakes) for my audax bike .... instead of HED Belgium rims
I'm looking at using a Son dynamo hub, tubeless tyres, and from a previous post, you mentioned that it's best to use 36 spokes on the front, aswell as the back.... do I get symetric or assymetric?
HEd Belgium are not assymetric
Trek Emonda SL6
Miyata One Thousand
bm0p700f
by bm0p700f
I have all the XR series 32H for disc brake.
bobones
by bobones
Miller wrote:
Mon Mar 05, 2018 9:17 pm
Not exactly cheap for winter use @ £60 per rim, and there are numerous reports of them being difficult to mount tyres on. Nice and light though, and probably a very good rim in other respects.
bm0p700f
by bm0p700f
I have no trouble fitting tyres to them those that are having trouble are probably using std rim tape. tubeless tape must be used.
alcatraz
by alcatraz
Would it be possible to go 2:1 lacing 16/8 on this powertap hub and a 24h rim?
Maybe the NDS spoke holes won't line up right.
/a
alcatraz
by alcatraz
NovemberDave
by NovemberDave
alcatraz wrote:
Wed Mar 07, 2018 1:34 pm
/a
Powertap hubs require at least 2x lacing on the non-drive side. I can't explain it completely, but the torque is transferred through to the non-drive spokes as part of the torque measurement. Which means no 2:1 lacing on Powertap hubs
