Bearing recommendation
- Contact:
Looking for a good 6802 that doesn't break the bank.
i've had good results from Enduro bearings. they make regular, hybrid and ceramics. all good. not sure how they compare to Ceramic Speed.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Avoid "cycling" brands. Or rubbish or extremely overpriced for what it really is.
Best what money can buy are SKF, INA, NTN and Timken. Buy stainless. Peace of mind for very long time.
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
^Spot on, you won't find much better quality than these-
https://www.hambini.com/bearings/ultra- ... -seal.html
Steel has more load capacity than stainles steel.
What about EZO?
True. But any 1st class bearing made for industry is overkill for cycling. From loads to speed.
Our assumption is that "cycling" brands made bearings from high grade steel... and we're usually very wrong. Stainless Timken or INA use best money can buy stainless steel for this purpose. See the difference ? From my experience stainless from brands I mentioned will easy outlast anything "cycling".
Loads and stresses for any bearing in bike are very low in comparison to what they're designed. So no worries.
I work with stainless (fasteners) on daily basis. You'd be very surprised how much of various forces stainless steel can take and still remain "untouched".
BTW DT 240 use inox .... and reliability of 240 is rather a strength, not weakness.
Mark Twain
Mark Twain
I think problem can be with loweight hub designs
Smaller bearings - and softer material (if they use Stainles steel) - lower bearing life
Most that kind of hubs using 17mm axle - and in freehub body bearing size 6803. So some companys has an option with double bearings in this place
6903 is too big for freehub body
- Contact:
So I pulled the bearings out of my wheelset. The rears were toast. There are (4) 6802's in there. The front wheel didn't feel bad, but I swapped them anyway and after comparing the out-going set with the ingoing, the old ones were definitely on their way out. The front hub had (2) 699 bearings. All of the bearings are labeled as being from TPI and they are supposed to be ceramic. They had a rubberized/plastic type material dust shield and still had a fair bit of grease inside. This wheel set has seen a LOT of miles... hard miles. The replacement bearings came from a used wheel set that my friend had. It was the same exact spec. He had put maybe 800 miles on them and stopped using them because he was worried that he was close to weight limit and he felt they were too flexy for him. I think I will ultimately get some NTN bearings from that Hambini site to replace them.
If you are in the US, you can get NTN bearings at advantageous prices from Misumi. I got a set of genuine NTN crank bearings from them for less than $14 each. I have a Hambini BB, but don't need to pay UK prices and shipping for something arriving in Atlanta. Misumi is a full NTN stocking dealer, and they are members of the anti-counterfeiting organization here in the US as well so you know you are getting the genuine deal from them. Customer service, shipping, etc., all outstanding.
https://us.misumi-ec.com/
lance - no, not that guy, I started racing in 1976.
1980 A-D Ultima
1999 Softride TT
2013 Cervelo S5 Team LE
1980 A-D Ultima
1999 Softride TT
Thanks for sharing. I just bought some 6903's from Hambini. I paid $15 USD each. I looked up the same bearing at Misumi and it's only $7 each. How can Misumi sells it for half the price of what Hambini is charging? Misumi looks to be legit however I'm always a bit skeptical when something is significantly cheaper especially for a commodity part.
