DT Swiss ARC 1100 Dicut 48
MichalZZZ
by MichalZZZ
Hello,
I previously owned Zipp 303 Firecrest wheels. Now I can buy DT Swiss ARC 1100 Dicut 48mm. (2018 year and rim brakes version) Could you compare both of them together? Would you say they are similar level of wheels? If not which one is better ?
Thank you.
TonyM
by TonyM
Which size of tires are planning to have? 25mm or 28mm or more?
(the ARC are made for 23/25mm; the ERC are made for 25/28mm)
I have on my winter/ rain bike the ERC 1100 Dicut 47 DB with 25mm Conti 4 Seasons (winter) and they are really fine. Of course I could have also 28mm on these ERC.
MichalZZZ
by MichalZZZ
25mm.
TonyM
by TonyM
If you never go with 28mm the ARC are indeed good.
If you want to go with 28mm or if you ride with less than 35 kmh, the ERC with 28mm may be better (that what DT Swiss is claiming; The tires used were Conti 4k)
https://www.roadrevolution18.dtswiss.com/endurance/
scroll to the bottom of the page to "rolling resistance"
It also depends if your frame has enough clearance for 28mm tires (measuring usually 30 mm)
spartan
by spartan
i would go 25mm front 28 mm rear.
aero on the rear wheels has minimal penalty
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
TonyM
by TonyM
spartan wrote:
Thu Jan 25, 2018 2:03 am
That's indeed a possibility. In that case the OP would however need to get the ERC instead of the ARC.
BTW DT Swiss recommends for aero purpose to run 23 front and 25 rear on the ARC.
khayale
by khayale
TonyM wrote:
Thu Jan 25, 2018 5:57 am
Hi. First post.
Very interested too if anyone has any experience with the ARC 48s.
That said, the ERC is only made for disc brakes so it wouldn’t work for the OP. A good option but alas.
MichalZZZ
by MichalZZZ
In this price range I can find better wheels? (clincher, rim brake, around 50 mm high) I am looking for aero wheels that can cope with side Irish wind. flat and also mountains tereins.
TonyM
by TonyM
MichalZZZ wrote:In this price range I can find better wheels? (clincher, rim brake, around 50 mm high) I am looking for aero wheels that can cope with side Irish wind. flat and also mountains tereins.
And DT Swiss quality for the hubs, spokes, rim and assembly!!
Go for it!
MichalZZZ
by MichalZZZ
What do you think about Zipp 404 NSW ? it will be a better idea? Or stay with DT Swiss ?
TonyM
by TonyM
Zipp claims that they are very good in cross winds. Can’t tell you if right. Maybe there is a review of these in crosswinds.
The ERC (so therefore the ARC also as they were made with this topic in mind) are good in the crosswinds I have but I ride approx. 49 km from the sea coast here in Canada/ British Columbia.
If you like the design of the NSW go for it. If you want or need the quality of the hubs, spokes, rim and the overall manufacturing quality of DT Swiss go for DT
dinesh2988
by dinesh2988
Did you got your wheels ?
I just ordered my DTSwiss ARC 62 ... Would be getting them in next 8-9days ...
TonyM
by TonyM
dinesh2988 wrote:
Thu Feb 01, 2018 5:44 pm
Post a review :wink:
I am also interested to have some (as the Shimano Dura Ace 9170 C60 seems to be available in only a few months....)
Lafolie
by Lafolie
wondered if anyone pulled the trigger on a pair of the DT Swiss ARC Dicut 48 ?
spartan
by spartan
new bontrager wheels coming april 1. i would wait another week before pulling the trigger ;)
Current Rides:
