My replacement Campy Bora Ultra 50 wheels showed up with the wrong hub :(
Noctiluxx
by Noctiluxx
After waiting 6-weeks for my defective wheels to be replaced under warranty, Campagnolo service facility sent me the rear wheel in the wrong hub. I sent in Shimano hub bora ultra 50's and got back a Campy version :cry:
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2017 Giant TCR Advanced SL (Red)
2016 Specialized Allez DSW Sprint (Gold)
2016 Giant Anthem Advanced SX (FS)
2018 Trek Farley EX 9.8 Fatty (FS)
F45
by F45
That's a bummer man. You can either complain and work to get a new freehub from them or put a Campy cassette on there and get riding. Assuming you have 11 speed.
sungod
by sungod
on some campag wheels can't you just swap the freehub body?
if yours allow it, then if they put the wrong one on, they should ship you the correct one so you can change it over, faster and less hassle than shipping the whole wheel back and forth (at their cost)
Digger90
by Digger90
It's a simple swap - just call 'em and they'll replace it.
ferrarista
by ferrarista
It takes 2 minutes to swap. Just call them and they will ship you the Shimano freehub.
bikerjulio
by bikerjulio
Freehub is easy to swap - but you need to know one key thing.
The freehub retaining nut is reverse threaded, it unscrews clockwise.
So,you need a 5mm hex key on the NDS and a socket wrench on the DS retaining nut.
There's sometimes a buggy.
One.
ferrarista
by ferrarista
bikerjulio wrote:
Sun Dec 17, 2017 10:43 pm
The right way to do it is to use the 5mm allen key and 17mm wrench both on the drive side. The NDS 5mm cap is there so you can remove the axle when you have to do bearing maintenance, etc...
It should not be used to screw or unscrew the DS freehub retaining nut.
Noctiluxx
by Noctiluxx
I ended up getting a Shimano free hub replacement and had it installed locally. Thanks for all the help!
