Wheel set recommendations and suppliers for a new bike build
apctjb
by apctjb
Getting ready to build a bike and looking for recent recommendations for wheels manufacturers/ suppliers.
Looking for light weight (<1400g? ), rim brake complete 700cc wheel set suitable for 25 or 28cm clincher tires, for climbing and general riding (non aero), and good quality hubs . Wheels will be used on a Workswell 93 frame.
I have seen Yoeleo mentioned on this form as one possible supplier... others?
Thanks
mortirolo
by mortirolo
Campagnolo, Fulcrum
Marco Pantani - Momenti Di Gloria
apctjb
by apctjb
Campagnolo, Fulcrum
Thanks; I should have mention price point of <$1200 USD
morganb
by morganb
Do they need to be carbon?
Hexsense
by Hexsense
suitable for 25-28mm <-- means
internal width >= 18mm (19 or 21mm prefered) for good tire shaping. you can then lower pressure compared to narrower internal width rim or keep the pressure and enjoy even more reduced rolling resistance compared to just wide tire on narrow rim.
external width >=27mm (30mm prefered but not available under 2000 (Roval CLX 32,50), new updated Enve 4.5, new updated Zipp 303 NSW disc tubeless). for being aero too. Ignore if you really sure aero doesn't matter.
DT Swiss have some 19mm internal 27mm external width but may be a bit over your budget.
HED JET 4 PLUS is budget and wide but being hybrid alloy+carbon it's over your weight limit.
for Chinese carbon fiber, take a look into Light-bicycle 36mm and 46mm. Both have 21mm internal width and 28mm external width. For your requirement 36mm seems to fit better. Build it with Novatec 291+482 SB-SL for light cheap and decent hub.
Venn Rev 507 (50.7mm) 21mm internal width, 27.9mm external width might be over your targeted weight.
There are many many many Chinese or non-Chinese rims emphasize on being more aero by keeping the internal width narrow (<17mm) and increase only external width. This sacrifice some nice rolling property of wide internal width rim to ensure they don't need to make rim really wide for aero advantage. I found this concept alright if all you want is aero. But i prefer internal width to be wide, and make external width even wider to support increased tire width.
for alloy wheel,
Pacenti Forza is 20mm internal, 24mm external so 25-28mm will form very nice shape which will roll well. but it won't be quite aero since rim isn't wide enough to smooth out air from wide tire.
it's pretty cheap too. "Special kit" from bikeHubStore cost only $399. but weight 1495g which is 95 grams over your target.
I own Light-bicycle 46mm and Venn Rev 507 so you can ask me about those two rims.
ddsg
by ddsg
The Flechtwerk wheels from Bike-Components.de could fit the bill. $900, claimed weight of 1370g. Comes with titanium skewers.
ddsg
by ddsg
And to add onto the HED suggestion above, you can find a set of Jet 4 Blacks (black textured brake track) if you're willing to sacrifice weight for better braking. If you're doing a lot of descents, it could be worth it.
apctjb
by apctjb
Thanks for great post. Very helpful
dim
by dim
consider tubeless ready rims
Giant TCR
Canyon Endurace AL
Specialized Allez Sport
Broady
by Broady
These new Hunt wheels look spot on, £949 - 1417g - https://www.huntbikewheels.com/collecti ... f3c278be38
kidrob
by kidrob
ddsg wrote:The Flechtwerk wheels from Bike-Components.de could fit the bill. $900, claimed weight of 1370g. Comes with titanium skewers.
Yeah, they are very decent, I enjoyed them a lot so far, can recommend!
ddsg
by ddsg
How do they brake in the wet? I'm actually between these or a set of Flo45s right now.
kidrob
by kidrob
Didn't ride them in the wet yet. But riding in the wet with carbon wheels is generally not that great idea... :roll: :wink:
Apparently the German "Tour" magazine test them in this month's version, I will try to get hold of it.
