Enve Black Texture Brake Pads on 6.7?
Anikdote
by Anikdote
Basically what the title says.
I'm just curious if anyone here have experience using Enve's Black Texture Brake Pads on 6.7?
I know the black pads are only for use with updated brake track found on ENVE SES 2.2 , SES 7.8 and most recent versions of SES 3.4, and SES 4.5 wheels.
Thanks!
kode54
by kode54
i'm sure the experience would be similar to that on the 3.4, 4.5 and 7.8.
what are you concerned with? brake squeal?
- AX Lightness Vial EVO D + DA9150 + Enve SES 4.5 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Guru Praemio R Titanium + DA9150 + Enve 3.4 CK hubs
Anikdote
by Anikdote
kode54 wrote:i'm sure the experience would be similar to that on the 3.4, 4.5 and 7.8.
On Enve's page, it says " Use of the ENVE Black Brake Pad on SES 3.4, 4.5, 6.7, and 8.9 model rims and wheelsets with the standard braking surface will diminish braking performance and voids the warranty."
I was wondering if they're better in braking performance compared to grey pads on the 6.7 and if what Enve said was true about diminish braking performance.
RyanH
by RyanH
Enve pads are useless. If you have a smooth track, use Reynolds Power Pads and for textured use Black Prince. I honestly can't believe Enve specs such a crappy pad for their rims. No wonder so many people feel they need disc wheels.
fa63
by fa63
Doesn’t the use of non-Enve pads void the warranty? I know it is important to be able to stop and what not, but wouldn’t want to ruin warranty on very expensive wheels either.
NiFTY
by NiFTY
All this voids the warranty stuff - 1) how would they know. 2) if you are looking at nonstandard brake pads due to poor braking and a different pad improves braking power - is a void warranty not worth a-void-ing an accident. I use campy red on all my carbon rims as it brakes better than the recommended pads (xentis, meilensteins and ax lightness)
