WI T11 service interval
silvalis
by silvalis
Noticed my T11 bearings were a bit crunchy (only 5k on it) and dropped it to the lbs for a service. Was told that T11's did not have good sealing and requires regular service? I was under the impression that they were one of the better hubs in terms of sealing/service?
How often does everyone normally service their T11s?
Was told by the LBS that to get the hubs serviced each time i drop the bike in as well, but as I tend to do servicing myself is this like... every 2000km?
Also had the driveside end cap fall off. That was a new one. Searching the forums it doesn't seem uncommon?
Chapter 2 Tere
Scott Spark 720plus
jlok
by jlok
I had the CLD and agree that the rear freehub sealing is minimum. One rubber o-ring at the freehub and hub shell interface and they don't seem to stick too close. Water is easy to get into the ratchet ring / pawls compartment.
Apart from the cassette lock ring there is no cover for the freehub outer bearing as far as I could remember.
So yes they are more exposed to the elements than hubs like DT Swiss. I destroyed the bearings by shooting too much degreaser at the cassette while the wheel is still on the bike. But still, I love these hubs. Well made and beautiful. Take care.
silvalis
by silvalis
hmm. Shooting degreaser at the cassette could have been my issue too...
Chapter 2 Tere
Scott Spark 720plus
NovemberDave
by NovemberDave
https://novemberbicycles.com/blogs/blog ... stries-t11
Long story short: if you get too far from the fairway, the bearings in WI hubs can suffer. But apart from that they're outstanding hubs and a very good value.
bm0p700f
by bm0p700f
always remove the cassette and chain before degreasing that applies to any hub.
