Can I buy this tubular wheel and fix it?
Sm0421
by Sm0421
https://www.ebay.com/i/172704271596
Found this C35 rear wheel on eBay and is exactly what I needed since I broke mine in a race. Problem is that it looks like the brake track is damaged on one spot, hence the low price. Do you guys think I think I can buy this and go to a LBS to get it fixed?
Thanks so much!!
Alex
AJS914
by AJS914
What part is the LBS going to fix? carbon repair? Or swap rim from your wheel?
Geoff
by Geoff
There is no telling what has happened to that wheel. Not recommended.
Sm0421
by Sm0421
Thanks guys! Since I broke my C35 tubular I've been using a C24 clincher for about a year now while keeping the front C35 tub, any recommendations on a good <$600 read deeper rim wheel? Been thinking zip 303.
LouisN
by LouisN
This might do, and let you use the same spokes if they're still useable:
https://www.lightbicycle.com/35mm-deep- ... rface.html
Louis :)
