Disc front hub on non-disc frame
Multebear
by Multebear
Inspired by this post I was considering building a front wheel with a hub dynamo for winter training. At the moment I'm riding with rim brakes. But since no one knows what the future holds, it's not ruled out that I will ride with discs in the future. So on order to be prepared for that, my question is: Would cause any problems to build a front wheel with a disc hub on a rimbrake rim and ride it with rim brakes for now. The spacing is the same and both are with QR's. And if I want to ride it with disc brake in the future, I'm just gonna mount a disc on the wheel/hub and ride it like that. Any thoughts?
I'm aware that thru axle probably will be the standard in the future. But let's not focus on that for now.
joejack951
by joejack951
No issue at all, unless you consider a slightly dished front wheel, slightly more weight, and, eventually, using a rim brake rim on a disc brake wheel in the future an issue. Seems like a reasonable idea to me if you plan to keep this wheel for a while.
ergott
by ergott
I have a front wheel like that
Sent from my SM-G950U using Tapatalk
Lelandjt
by Lelandjt
I think your last paragraph is the hitch. There will be no point in doing this* because if you do eventually want to move the wheel to a disc frameset the axle won't match up. I mean, right now there's still some QR/disc forks but in 2 years?
*The only reason you should bother is if you find a dynamo hub with swappable end caps so it can be switched to thru-axle later. This is common on MTB hubs but I doubt a dynamo hub with swappable end caps exists.
MikeMoore
by MikeMoore
I do this. I run a QR disc dynamo hub on a non disc frame.
If you want to future proof, the SP PD8X comes with adaptors to run a 15QR in a 9mm QR frame.
https://thecycleclinic.co.uk/products/s ... dynamo-hub
Weight 72kg, FTP 289W => 4.01 W/kg
Custom ti 650B Kingdom Double9 (with tubs)
Kinesis Aithein
Kinesis Racelight 4S "Rain Bike"
Ventana El Conquistador
Multebear
by Multebear
^Nice, that's what I'm looking for.
Multebear
by Multebear
So I was trying to find the right length spokes for this build. I'm using a Mavic A119 rim, and 32 spokes in 3x config. Does this look right?
293.2 left side and 294.7 right side?
MikeMoore
by MikeMoore
Looks correct to me. I'd go for 292 and 294, probably with Sapir DLights.
Kinesis Aithein
ooo
by ooo
Why 32 spokes for "winter training" wheels? May be be 24-28 spokes?
Multebear
by Multebear
Thanks Mike Moore
ooo; 32h opens options for a wider selection of rims. Just about every rim on the market comes in 32h. Especially the cheapest and most durable ones like Mavic low end, Open Pro's, A119 e.g.
Multebear
by Multebear
Nice ooo. Didn't know 28h open pro's were available.
I've just finished a wheelset with Shimano 105 hubs and Mavic A119 rims 32h/32h. I'd like the front wheel with dynamo to match that wheelset with the same rim. So if you find the Mavic A119 rim in 28h, I would be really interested.
