Stan's sealant in tubes for puncture sealing?
WinterRider
by WinterRider
Anyone tried this ... giving tubes a shot of Stan's or similar for puncture sealing? Long term the drying issues.. but don't all sealant's do same (?). How much to use 700c w 28's?
My batch of Continental tubes have removeable stems. For sister's bike.
Kayrehn
by Kayrehn
Use it only when you get a puncture, unless you are racing those wheels and hope you don't get slowed down with minor punctures. Maybe 20ml? I don't use a lot, but can't remember much since it has been more than a year since I last had to use it ha.
dtwolfen
by dtwolfen
I've found stans in tubes does not work as well as a chunkier sealant, I use slime that I put in a tube with a hole in already then patch it up. The patch usually fails but it takes about a year. Don't need much but I don't know how much is enough.
Sent from my LG-H700 using Tapatalk
ms6073
by ms6073
For latex tubes and tubulars with latex tubes, I have reasonably good luck with Effetto Mariposa's Caffélatex and Orange Seal has been hit or miss with butyl tubes, but keep in mind that over time, the sealant can solidify.. Regardless of the tube, be careful as it only takes a little bit to clog a valve stem with removable cores making inflation a challenge.
AJS914
by AJS914
Does Slime not dry out? Maybe it would be better for the sister's bike? Or, just get her some Mr. Tuffys or some Gatorskin tires. Or, all three! She'll never get a flat.
WinterRider
by WinterRider
AJS914 wrote:Does Slime not dry out? Maybe it would be better for the sister's bike? Or, just get her some Mr. Tuffys or some Gatorskin tires. Or, all three! She'll never get a flat.
She's... going to the WW side.. wants more speed.. LOL.
The green slime via wallyworld in my one experience trying it is garbage. Consistency was poor.. lumpy and I did not think flowed well enough. Could be wrong.
Think we'll fly sans anything. Tuffy's too heavy........ slow her down. :unbelievable:
sussexhills
by sussexhills
Stans works alright in tubes, I generally find it doesn't last that long before a huge sealant monster forms, must be do to with the dusty butyl inners or something. Therefore works better to just keep a small bottle in jersey pocket and put in if required (or go tubeless).
ms6073
by ms6073
Stans contains ammonia which for tubeless applications, can be detrimental to alloy spoke nipples, but probably not as much of a factor when injected into Butyl inner tube.
