Pirelli Pzero family tire discussion thread.
Forum rules
It's because the extra material thickness (chafe strip) changes the stress on the rubber at the point where it ends; there's quite a bit of movement in the tire casing there from normal riding. I have found it to be inconsistent across brands, but in my experience this happens with Continental tires much sooner than Michelin. I'm not really sure why.MagicShite wrote: ↑Sat Oct 30, 2021 4:44 amyeah the fine lines that present itself as a light tear. It's all around the tire though so it's not just a localized spot. It's like a tear more than anything else.tjvirden wrote: ↑Fri Oct 29, 2021 6:18 pmI think they're fine - I assume you're referring to the "cracks" parallel to the brake track( here the chafe strip ends). These usually pull away a little; as long as it's only a little then they're fine to use.MagicShite wrote: ↑Fri Oct 29, 2021 3:13 amyeesh, can someone please advise if these are still usable? I only have 1200kms on them...MagicShite wrote: ↑Thu Oct 28, 2021 9:26 amSome small fine "crack lines" forming on the sides of my pirelli velos. Anyone knows if this is still safe for use?
Why would they tear at the first place? I've never seen this kind of wear before.
Hello, I searched on this topic, but I didn't find anything about the "old" tubular Pirelli Velo Race Tub.
This one https://www.pirelli.com/tyres/en-ww/bik ... o-velo-tub
I'm using them, the 28mm size, but I've a strange feeling. In the past I used for racing both Vittoria Corsa Graphene 25mm and Continental Competition 25mm and for everyday ride/training Continental GP5000 tubeless. Always, when I shifted from tubeless to Continental Competition tubular, I went faster. I mean in the whole ride, so included climbs, flats and descends. Now with the Pirelli tubular I don't have this result. They are really grippy, both on the corners and when I brake. I use disc brake. But, they seem to not roll very well. The rolling resistance seem to be high, but it's impossible to check without instruments. On the Internet I didn't find any test about it, so I'd like to ask you if you'd tried them and have any feedback? Thank you
Does the 25c looks sketchy on the 23mm ID rim? I was thinking of this comboHexsense wrote:on a huge 23mm internal width rim (30mm outside):
Pirelli Pzero Velo 25c -> 29.8mm
Pirelli Pzero Velo 28c -> 30.89mm
The 28c is noticeably taller, as expected though.
Envoyé de mon SM-G973W en utilisant Tapatalk
Hi folks, I'm trying to get some clarity here. I'm looking for new tires for my 3T strada and would love to go pirelli. I have compatibility for 30mm wide tires and a maximum of 344mm radius. I'm having trouble finding the most accurate "RAM" measurements for P zero velo race tires. I see P zero race 30mm as 344mm:
The TLR version appears to go up by 1.5mm:
Are these accurate? I cannot find any info on the pirelli website for RAM or WAM. I would love to go tubeless but I can't risk the bump up in radius in terms of clearance.
Yes those are pretty accurate. Wider tire will ride taller. I can't risk using bigger than 24mm because the seattube curve is already very close to the tire.
it's not 1.5mm, it's 15mm, divided by two that's over 1/4 inch closer to the seat tube.
691/2=345.5. My max (based on a comment by the bike builder) is 344mm. I guess I'm just surprised that the same tire from the same manufacturer in the same size is taller in the tubeless format compared to clincher, especially when the rest of the sizes seem similar or identical.PoorCyclist wrote: ↑Sun May 22, 2022 8:19 pmYes those are pretty accurate. Wider tire will ride taller. I can't risk using bigger than 24mm because the seattube curve is already very close to the tire.
The 30mm clincher non-tubeless matches the specs perfectly, and could be the ticket I guess.
I believe if you mount them on wider rim, it should be decreased some amount in overall diameter, the pressure on their chart also gives a rock hard ride that is not practical. If you have a gravel type rim it might work.
