Disc brake AND rim brake?
MiddMan
by MiddMan
I have never used disc brakes, nor am I in the field of engineering, mechanics, etc., so this is an honest question: has anyone tried, or is it even possible, to run one disc brake and one rim brake?
For example: disc on rear and rim on front. I realise this would require a unique set up including: a) a bike with disc compatible rear and rim compatibilie fork, b) two unique wheels, c) perhaps two separate levers. And d) the 'feel' of the braking would also probably be different. But, unless I am missing something here, it would seem to be a good compromise:
The front wouldn't look so ugly, nor would there be a sacrifice in aerodynamics. It would also be lighter. The back already has the cassette, so the disc 'blends in' so to speak, and there's probably little to no aero penalty. Yet it would give extra/safer stopping power on the steeps when using carbon wheels.
Given what I've already mentioned, what would be other pros and cons (or impractical/impossibilities) to such a set up?
MiddMan
by MiddMan
FWIW I have no intention in trying this, I'm merely curious!
glam2deaf
by glam2deaf
It's been done the other way around, though there are practical reasons why.
Though seriously, I don't really see the point. Aside from looking weird, all the mis-matched parts you're going to end up with and the effort required just doesn't seem worth it.
silvalis
by silvalis
I reckon it would be more practical to have a disc front and rim rear...
Chapter 2 Tere
Scott Spark 720plus
jlok
by jlok
I think one could easily fit a disc brake fork to rim brake frame.
The question would be the value of doing it. If you want disc brake because of the safety concern with carbon rim braking, you better go full disc brake rather than buying a disc brake fork.
dmulligan
by dmulligan
I've often thought about putting a disc brake fork on my cross commuter bike because cantilever brakes suck. I think that my Tiagra 4400 brifters would be compatible with a cable actuated disc brake so the number of parts needed would be minimal. It also allows me to keep the rear wheel compatible with the rest of my stable.
Sent from my A0001 using Tapatalk
alcatraz
by alcatraz
I've been thinking about such an upgrade. I'm happy with my current bike in almost all aspects and don't wan't to change it really. Only braking is not up to par...
A fix would be to get a disc brake fork and do a mechanical setup. That way I don't have to worry so much while descending.
On a motorcycle they say braking performance is like 90/10 front/back. On a bike its more even but the front wheel is going to take up most of it.
Doing it on the rear sounds like a backward idea to me though. You're trying to improve a place where braking is already limited.
/a
jlok
by jlok
alcatraz wrote:Doing it on the rear sounds like a backward idea to me though. You're trying to improve a place where braking is already limited.
/a
Not if...
1. you have carbon rear wheel, and
2. you ride in wet days (or it suddenly rains and you keep riding)
it hurts to brake with rim brake when it's wet... the dirt paste accumulated on the pads will be like sand paper scratching your precious rim...
mattr
by mattr
MiddMan wrote:But, unless I am missing something here, it would seem to be a good compromise:
Nope, bad compromise, disc should be on the front where ~75% of the braking load can be applied. Disc on the rear is only any good for specific types of bike. i.e. bikes with no facility for a front brake (jump bikes?) or possibly delivery bikes, or those towing trailers or significant loads over the rear wheel.
MiddMan wrote:Yet it would give extra/safer stopping power on the steeps when using carbon wheels.
On the steeps you'd get even less braking as the weight shift to the front wheel would be greater and quicker. As you will already be shifted slightly forwards
MiddMan wrote:Given what I've already mentioned, what would be other pros and cons (or impractical/impossibilities) to such a set up?
Cons 1) Not able to stop effectively. 2) Have to replace your frame (expensive)
Pros 1) can do massive skids
Just buy a new fork and stick a disk on the front. Pretty sure you can still get disc hubs with rim brake rims. So you can even use the same wheels.
My wifes MTB was set up like this for ~10 years. BB5 on the front XTR V on the back some mavic Cross ride wheels. The wheels were still in very good condition (rear really doesn't get much wear unless you ride in *really* crap conditions and never clean the pads/rims.)
mattr
by mattr
glam2deaf wrote:Though seriously, I don't really see the point. Aside from looking weird, all the mis-matched parts you're going to end up with and the effort required just doesn't seem worth it.
Most road frames come with no disc mounts, so this is an easy way to get good commuter/wet weather performance without splashing out on a new frame. Should cost around €300 for mech discs and "commuter" level kit (road)
Multebear
by Multebear
Kinsesis 4S disc has option for both disc and rim brake both front and rear. Might be good to do you experiment on.
http://www.kinesisbikes.co.uk/Catalogue ... ht/4S-DISC
pdlpsher1
by pdlpsher1
This is a very common setup on tandems. A tandem has a wider rear dropout spacing hence the disk on the back is a no-brainer. The front brake isn't needed often and it's only used for emergency stops. One can pull on the rear disk brake lever really really hard and the rear tire will never lock up due to the extremely high coefficient of friction on a rear tandem tire.
dmulligan
by dmulligan
Someone else mentioned this but I forgot to mention too when I spoke of my ideas regarding a front disc brake... When I was more interested in making my Jake lighter and/or upgrading it I partially wanted the disc brake so I could have carbon clinchers without worries. Since then my Jake has been relegated to mainly commuter duty. However the rest of what I said is still true. Cantilever brakes suck and for that reason I'm still interested.
However one wheel mismatch I'm surprised I've never seen is a front carbon wheel with an aluminium brake track in the front and a full carbon wheel in the rear. I've always thought that combination would give be a good compromise between braking performance, safety and weight. Now I'm thinking that I need to build such a front wheel for my road bike...
