Wheel recommendations for a Wilier Cento 10 air ( Ramato)
Lafolie
by Lafolie
Folks - decided to pull the trigger on a Wilier Cento 10 air in the Ramato colourway. Can't decided what wheels to put on it. Any recommendations or thoughts would be much apprecaited.
Delorre
by Delorre
Spectacular bike :shock: What's wrong with the stock wheels? Will you go clincher or tubular? What is the intended use? Unless you want something way lighter, I would keep those ;-)
Lafolie
by Lafolie
Above pic is for reference only. It's not my actual bike. I have just order the frameset and bar.
snowdevlin
by snowdevlin
Lightweight wheels would suit nicely
Such a beautiful frame although I cannot see why the integrated bars are designed that way (pointing upwards that is...).
I would love a full Campagnolo groupset and Boras but with your DA groupset Fulcrum or LWs would be great.
Lafolie
by Lafolie
cheers guys
2lo8
by 2lo8
Vintage Campagnolo Shamals. You know the ones.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
Fiery
by Fiery
kgt wrote:Such a beautiful frame although I cannot see why the integrated bars are designed that way (pointing upwards that is...).
It's a custom combo for Pozzato, matches the position he uses with a standard stem and bar setup. See this one or this one, for example.
corky
by corky
I recommend at least 2
The fact Pozzato uses this setup does not say much... It just doesn't look right.
snowdevlin
by snowdevlin
corky wrote:I recommend at least 2
:beerchug: :beerchug: :beerchug:
wingguy
by wingguy
kgt wrote:The fact Pozzato uses this setup does not say much... It just doesn't look right.
It says that it's not the same as the customer version...
benzebub
by benzebub
:goodpost:
But I could be wrong
glepore
by glepore
I have a cento uno air, but really want the new frame, just can't justify the cost. The black/orange/blue and the colorway above are stunning.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
Lafolie
by Lafolie
ok... I have narrowed it down to either
Enve 4.5
Miche SWR 50
Ursus 50
dt swiss arc 1100 48
