Bora Ultra 35 vs. 50
Mep
by Mep
eurperg wrote:There's no weight difference between Bora 35 Ultra and 50 Ultra, at least not in the pair I have weighed. Actually the 50's were a couple grams lighter! There are many real weights in the Bora topic on this forum. The 35's have a more neutral and unnoticeable feel, whereas the 50's are more noisy. That is something you either like or not like... The pre-2015 Ultra Twos were not as good in crosswind as the new 50's. I have ridden both back to back and do not regret buying the 35's.
No weight difference? That can't be right...
Zakalwe
by Zakalwe
saeie1 wrote:I chose 35 to climb the hill quickly, but I want to use it for visuals 50
There's a 55g difference between the two listed weights, can you feel that on the hills?
Calnago
by Calnago
My Bora Ultra 50s:
Front: 538
Rear: 700
Total: 1238 (without skewers)
My Bora Ultra 35's:
Front: 500
Rear: 676
Total: 1176 (without skewers)
Difference: 62g
Can I feel that on the Hills? No
Can I feel a huge aero difference on the flats?: No
They are both great wheels.
3Pio
by 3Pio
Something is strange here.. I measured my Bora One 35 and they got 1165 gm (without skewers) .
Ill try to find pictures of the measuring, and post it here..
Calnago
by Calnago
With the Ultras... you're paying for the CULT bearings/races, not weight reduction.
3Pio
by 3Pio
Calnago wrote:With the Ultras... you're paying for the CULT bearings/races, not weight reduction.
Official weight on Ultras are lower then One.So their marketeting is that u pay for better bearings and lower weight in Ultra.
Anyway good to know that One are a bit lighter then Ultra
Calnago
by Calnago
Maybe they forgot a couple of ball bearings in your Ones. :)
3Pio
by 3Pio
Calnago wrote:Maybe they forgot a couple of ball bearings in your Ones. :)
Dont think so :) They roll so smooth :)
almost like they put CULT bearings by mistake :)
em3
by em3
Real weight on a calibrated scale for Bora One 50 and Bora One 35 tubulars (fresh from box with no glue applied):
Bora One 35 front; 495 gm
Bora One 35 rear: 690 gm
Total:1185 gm
Bora One 50 front; 525 gm
Bora One 50 rear: 685 gm
Total:1210 gm
...difference of only 25gm between 50s and 35s
Skewers on both wheels sets are identical weight:
Record Skewer front: 55 gm
Record Skewer rear: 60 gm
As far as difference in road feel IME...the 50s catch a bit more cross wind, but nominally. Also, the 50s are a bit less forgiving, vertically, where I feel a bit more of the road, but laterally they feel identical to the 35s, very stiff with a direct response when you put power down. They both climb like u r riding a hot air ballon. I run Vitt Pave 25c on both at 90 psi rear and 85 psi frt. The only advantage with the CULT bearings is the longevity of the bearings over the lifetime of the wheels (the CULT stuff when serviced regularly will last forever)....anyone who claims they can FEEL the difference of CULT bearings (compared to the hybrid ceramic USB bearings), is full of it. As others have suggested before, you can ALMOST buy a pair of Bora One 35 and 50 for the price of one pair of Ultras....albeit, I will admit that aesthetically the carbon hub shells on the 50s are bling. EM3
______________
saeie1
by saeie1
Tubular standard
35 - 1170g
50 - 1215 g
I don't feel much difference in weight,
I feel that the speed that I feel on the hill is not going to be a little bit steep,
This is not a big deal.
However, it is clear that both are good wheels!
hongsj
by hongsj
beauty : 50mm
climb : 35mm
weight : 35mm
tt : 50mm
TonyM
by TonyM
I am also looking at a Bora wheelset and I look it like this:
- Crosswinds, then Bora 35
- No Crosswinds, then Bora 50
- Only climbing, then Bora 35 (but Bora 50 also ok)
- Only flat, then Bora 50 (but Bora 35 also ok)
shineplus
by shineplus
35 is the uphill hill unconditionally favorable?
If I were to choose a visual effect,
bruno2000
by bruno2000
I just weigted a set of Bora ultra 35 clincher fresh from the box at 1400gr.
I weighted the same set with a different scal at 1359gr...
nom8099
by nom8099
No difference between 35 and 50? Need to check again~
