Who is running latex tubes on carbon clinchers?
Marin
by Marin
I put the tubes in a plastic bag with a bit of talc and shake. Butyl too usually.
ryanw
by ryanw
Conti Supersonics in my 404s with no issues. Actually made the ride better.
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
ms6073
by ms6073
We are running Zipp 303 FC and Nox Falkor 36D with Michelin and Vittoria latex tubes with no issues outside of normal wear and tear and the occasional flat from bits of road debris.
dereksmalls
by dereksmalls
Marin wrote:I put the tubes in a plastic bag with a bit of talc and shake. Butyl too usually.
I've never thought to do it like that, that's a great idea! Seems better than talc in the tire and rotating it around.
Marin
by Marin
dereksmalls wrote:I've never thought to do it like that, that's a great idea! Seems better than talc in the tire and rotating it around.
Plus, talc is getting a bad rep these days, seems you want to avoid breathing it in.
RJKflyer
by RJKflyer
Life will kill you at some point...
Marin
by Marin
yes but how
TonyM
by TonyM
Since I switch 30 years ago from tubs to tires I am using latex tubes (Vittoria, Continental, Vredestein, Michelin, etc....). They are much nicer to ride than the Butyl tubes (and it seems faster also).
I use latex tubes in all my wheels, also in my carbon wheels (Lightweight Meilenstein Schwarz Ed.).
However if I bike in the Alps for example, I switch to my alloy wheelset (Fulcrum Racing Zero), just because the security is then more important to me (I am over 50 y.o. and I dont't go anymore for the best time - which I anyway will never get again compared to my 20's).
When you use latex tubes, there are however some points that you have to be aware of:
- Use of talc is mandatory in order to avoid too much movement of the latex tube in the tire and the break of the valve.
- if you ride more than 4 hours, then the best is also to adjust the tire pressure depending on the duration of the ride (as the latex tend to loose some psi with the time). So put a little more when you start riding your 4-6 hours ride.
MattN
by MattN
ryanw wrote:Conti Supersonics in my 404s with no issues. Actually made the ride better.
That's butyl though so not relevant to running latex tubes in CC.
ryanw
by ryanw
I know, but it's a superior and lighter product, hence why I posted.
No issues with pressure loss, holds 120psi for a week no probs.
coloclimber
by coloclimber
No bad issues with vittoria latex on bontrager aeolus and vittoria and conti tires with cork pads in the winter. But I run tubies in the summer.
I am excited there are so many latex options and widths available now with Challenge, Bontrager, Vittoria, Michelin...
-Deacon Doctor Colorado Slim
duende
by duende
How's the ride? Pinch flats?
That's the thing for me with latex tubes. I almost never flat. Only when the tread on my tires is gone.
pdlpsher1
by pdlpsher1
Personally I don't run latex tubes. According to Enve the issue with latex is that running latex in a clincher rim is bad, regardless of whether the rim is made of aluminum or carbon. I agree with them 100%. Personally I have had horrible experiences using latex tubes in an aluminum clincher rim. I've had numerous blowouts and unexplained flats. Using the same installation method I switched to butyl and no more blowouts.
Currently I'm using Conti Supersonics with great results. 49g per tube and the rolling resistance is almost as good as latex without the safety hazard of latex.
Here the Enve warning on latex and clincher wheels. There's a good reason why Conti doesn't sell latex tubes you can buy but they use latex tubes in their tubular tires.
https://enve.zendesk.com/hc/en-us/artic ... her-Wheels
Johnny Rad
by Johnny Rad
Installation with latex is UNforgiving. Ask me how I know! Ha.
If I get a flat on the road, I replace my latex tube with a butyl one. I put too much pressure on myself to get the gang back rolling again so I pack butyl in my saddle bag. I replace the butyl with latex once I get home where I can methodically and precisely install the latex.
TonyM
by TonyM
Johnny Rad wrote:Installation with latex is UNforgiving. Ask me how I know! Ha.
+1. Same for me. Spare tube is always butyl (but I had a puncture maybe maximum 4-5 times in more than 30 years of cycling - with latex tubes)....
