Disc brake wheelset decision: Enve SES 3.4 4.5AR 5.6
Bordcla
by Bordcla
jlok wrote: ↑
Wed Jul 04, 2018 3:06 am
Thanks Bordcla, how about the tire pressure for that measurement?
Bordcla
by Bordcla
jlok wrote: ↑
I run anywhere from 55 psi to 65 and haven't noticed a difference in tire width or height. Even at max recommended pressure of 80 psi (only to properly seat the tire at installation; I would never run them anywhere close to that hard!), I did not notice a difference in size.
by Nefarious86
I'm still 50/50 on these over my CLX64s. At what point is wide too wide.
Sent from my SM-N950F using Tapatalk
Using Tapatalk
jlok
by jlok
I think I'd go ahead to order the 4.5 AR and Fusion 5 Performance TLR 28c or Pro One 28c. Hopefully they will not be wider than 31mm when mounted.
This wheelset is the best compromise between aero, weight and max air volume for me. Next best would be CLX 50 but I've tried that in the past so 4.5 AR with I9 hubs it is then. I like the orange anodized color to match my bike.
jlok
by jlok
just found that Grand Fondo used 25c GP4000S2 on the 4.5 AR!
https://granfondo-cycling.com/review-bastion-road-disc/
cwcheung
by cwcheung
jlok wrote: ↑
Thu Jul 05, 2018 2:23 am
I’m using 28c Pro One with 4.5 AR disc. I think it is wider than 31mm.
Speedvagen
cwcheung
by cwcheung
jlok wrote: ↑
Fri Jul 06, 2018 4:52 am
I doubt. It looks like 5.6 ...
Speedvagen
jlok
by jlok
Finally got to try the 4.5 AR. 30mm G-One Speed measured 31.5 and 30.7 F/R @50psi. I could slip a 3mm Allen key at chainstay so the clearance is acceptable to me. Order it right away!
Bordcla
by Bordcla
cwcheung wrote: ↑
Fri Jul 06, 2018 11:06 am
jlok wrote: ↑
Not sure where the doubt comes from. The article specifically refers to the 4.5 ARs in more than one spot.
cwcheung
by cwcheung
picture from the review
picture of my 4.5AR
The decal is wrong and i dont think ENVE will make this stupid mistake/error.
Speedvagen
jlok
by jlok
yes, they will make mistake. Rear wheel decal of my friend's 4.5 AR is wrong. It's from PWB.
cwcheung
by cwcheung
then make sure he got the right rim :D
Speedvagen
jlok
by jlok
The 4.5 AR rear rim profile is relatively sharp in SES series, with the hookless walls it can't be mistaken lol
cwcheung
by cwcheung
Ha Ha Ha. You just said they will make mistake. Anyway, when will you get the 4.5AR?
Speedvagen
jlok
by jlok
Lol u can’t make sure they won’t make mistake, but if they make one you surely can tell.
Mine will come two mths later from PWB.
