Using carbon brake pads on alloy rims?
Marin
by Marin
Any experiences using carbon brake pads on alloy rims?
My wiggle & Reynolds blue pads seem to work ok on alloy, if there are no shavings embedded do you think I can just leave them on when I switch wheels?
No, you should never leave the same pads when switching wheels. Filings from the alu rims, attached to your pads, will definitely harm the carbon surface.
mattr
by mattr
You only need one shard to mangle your carbon rims.
Marin
by Marin
Marin wrote:if there are no shavings embedded
sungod
by sungod
assuming standard calipers not hidden away, for the time/effort to check there's really nothing stuck in any of the four pads, you can swap them and not have the concern
mpulsiv
by mpulsiv
Why would you do that? Due to laziness?
miltmaster3
by miltmaster3
Just clean it . My TT bike has the brakes down and it is a difficult to make the change (I have to remove the crank) so I have the carbon pads and when I want to put my disk wheel just clean the pads
in watt mode
πατα τραβα ρε
mattr
by mattr
Really. Even scrubbing and/or filing pads down leaves shards of aluminum in the pad sometimes. And takes far longer than swapping pads.
And what sort of moron designs a bike that you actually need to remove the crank to change brake pads?
miltmaster3
by miltmaster3
Shiv TT small size
in watt mode
πατα τραβα ρε
fromtrektocolnago
by fromtrektocolnago
carbon pads are more expensive. what's the point? They might stop better, but were never designed for alloy wheels. Can only imagine unintended consequences.
http://www.visiontechusa.com/brake-pads ... on-wheels/
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Trek 5200(ultegra)
mattr
by mattr
miltmaster3 wrote:Shiv TT small size
what a mess. Someone needs a talking to!
Serious hat on for a moment.
Maybe drill a small hole in the chainring so you can get to the brake shoe bolt and release the pad. Put it next to or opposite the crank arm (lowest stress IIRC) but either way, a small neat hole in an aero ring won't make any noticeable difference. And it looks like it should be inside the inner diameter of the inner ring as well.
gmakris
by gmakris
you can remove the brake pad and shoe from shiv without removing the crank. Just change the alen bolt with a standard 12mm polygon head.
I would never keep the carbon pads for different types of wheelsets. Cleaning pads do not remove very small aluminium shards.
mpulsiv
by mpulsiv
Exactly! Aluminum shards are pushed deep into the brake pads, not visible to naked eye. Long story short, you are damaging you carbon brake track on your carbon wheels.
mattr
by mattr
gmakris wrote:you can remove the brake pad and shoe from shiv without removing the crank. Just change the alen bolt with a standard 12mm polygon head.
it was actually the small pad retaining screw I was thinking of
ergott
by ergott
Just ditch the retaining screw and don't try to use the brakes while riding backwards! :mrgreen:
You probably have to adjust the brake pad contact from wheel to wheel anyway so you might as well swap the pads.
