Velocite filament wound rims
moonoi
by moonoi
You're being paranoid, I'm using standard clinchers, on my wheelset, the Continental Attack/Force combination (23F/25R)
rangi69
by rangi69
moonoi wrote:
Tue Feb 13, 2018 7:34 am
Sweet, thanks - i have michelin latex 60mm tubes and gp4000's in 25mm here so will run with that! Did they mount ok?
moonoi
by moonoi
Mounted nice and easily, also using the michelin latex 60mm, but really there isn't quite enough of the valve showing for my track pump to get a nice seal, it's fine if your pump connects to the valve by screwing it on though
rangi69
by rangi69
Thank you, I appreciate the response. Bugger, I have a spare screw on pump but it’s a pain especially with how often you have to inflate latex tubes.
moonoi
by moonoi
To give you an idea, this is how much of the Michelin Latex 60mm valve is exposed from the rim
Sent from my SM-G950F using Tapatalk
rangi69
by rangi69
Arrived, finally after a wee battle with customs.. Set off yesterday Kom hunting and definitely felt faster. Did manage to get several PR’s. Not sure how responsive they feel up hills - I think the spokes could flex a little more than the straight pull from my fulcrum wheels but it’s early days. Braking is a non-issue in the dry. They are smooth and responsive under brakes and have that great carbon whirrrr. 25mm GP 4000 s11 mounted easily by hand and the sidewalls fit into the groove with a satisfying thunk around 70 psi.
I ran 100/95 psi rear/front and felt a little harsh. What is everyone running? I’m 72kg so not too heavy, might try 90/85 next.
Thanks for the help and advice, I’m happy as with the wheels. They came nice and true in the box. What’s the opinion on the Venn hubs? Will they last in the rain... I’d like to have these as my everyday wheels and get my $$$ worth out of them.
cassard
by cassard
I recently found this company, the 50mm Disc rims are very interesting. Anybody are using them ? any review ?
Hexsense
by Hexsense
Michelin 60mm valve latex tube expose long enough of valve on 50.7mm with Bontrager Turbo Charger pump to bite on easily. I think another 2mm less space and it wouldn't work.
It really depend on how much space your pump need if it is enough or not.
rangi69
by rangi69
My pump (lezyne) has no problem with the Michelin 60mm latex tubes. They are the perfect length IMO
biohazard31
by biohazard31
Hi,
I not sure if this was already asked here,but I want to know if there is any weight limit or recommended rider weight for the Rev 35 TCC, Alter 44 and 507 clinchers?
Thanks,
Emil
moonoi
by moonoi
biohazard31 wrote:
Mon Mar 12, 2018 3:42 am
Hi,
Thanks,
Emil
It's on their website, 110Kg for the 507
siim
by siim
romalor wrote:
Sun Nov 12, 2017 3:28 pm
Any progress on making the 507 VEN disc rims with a weight of 440 gr ?
vmajor wrote:
Tue Nov 14, 2017 7:42 pm
No, not yet. The new factory is now up and running so hopefully we will find the time soon to push forward with the r&d initiatives that go beyond stabilizing the manufacturing process.
Any updates on this? And rim-only availability of Rev 507 - is this planned?
adam0bmx0
by adam0bmx0
Got mine yesterday, chucked some GP4000 23mm tyres on (running inner tubes) and took them for a short spin. Happy with them so far, very little flex (72kg) and roll nice and smooth, breaking is great in the dry as expected. :thumbup:
Bike will be mainly used as my crit bike so weight not really an issue.
biohazard31
by biohazard31
(Double post)
biohazard31
by biohazard31
Sharing this screen grab picture from facebook. Too bad, no details given on this image so can't say anything about it. Anyone here had the same experience with the 35TCC / TCD?
